0 Gear indicator missing
Last Post: mrmom9r
0 1975 Sportster
Last Post: IronHeadRon
0 Transmission drain plug
Last Post: mvent
0 Indicators not flashing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
alto clutch, wet clutch ironhead, xlch, xlch clutch
Old 18th April 2018
P40Sporty's Avatar
P40Sporty P40Sporty is offline
Sportster/Buell Model: XLH 883-to-1200 Sportster
Sportster/Buell Model #2: XLH Sportster
Sportster/Buell Year #2: 1976
Other Motorcycle Model: 1969 XLCH Sportster
Other Motorcycle Year: 1969
P40Sporty will become famous soon enoughP40Sporty will become famous soon enoughP40Sporty will become famous soon enoughP40Sporty will become famous soon enoughP40Sporty will become famous soon enoughP40Sporty will become famous soon enough
Exclamation Wet Clutch - 66 XLCH - Not Engaging
So i just put new Alto wet clutch discs into my 66 CH. prior to doing the install i soaked the friction discs in a bowl of primary oil which is what i have always done with my later sportsters. So i finished the install. I kicked her over and got her warmed up and i noticed i had next to no tension on my clutch lever. Which either way i adjusted it would not get tension. For the hell of it i shifted it into gear and nothing. Bike dose not go anywhere. Im not sure where to start. The oil i soaked it in was a sportster primary oil threw bikers choice which i Believe is 80w/90.
Also something im wondering is if i should have not soaked the clutch discs. Even though they are wet clutch conversion discs maybe they are designed just to work even if they get wet but not to be submerged or totally wet
Also just for info , the bike never had a derby cover and it had clutch discs that appeared to be wet clutch conversion discs, the clutch i could get close with minor slipage , but wld either really slip or drag when adjusted, so thats why i decided to get new discs.
Any help from the old timers running wet clutches and no derby cover would be great
From one engine to another
