0 need help with 68 XLH
Last Post: fafcpa
0 Track Bike Build
Last Post: Tippy_Toes
Last Post: handa700
Last Post: d10221
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 22nd November 2018
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant future
Default 883/1200 Conversion,2002 Hugger w/S&S "bolt on"
Motor is based on an S&S “74XLSS” kit, which the previous owner had installed by an HD dealer in 2003. I purchased the bike about 6 yrs. ago; switched out the Andrews N6 cam which came with the kit for the Woods cam, and changed a Vance& Hines exhaust to the D&D. Chart was done a couple years back when the motor had about 20K miles on the conversion. It has not been professionally tuned, just some time on the Dyno at the HD dealer working with the jetting. Not bad results, all components are "off the shelf" without any modifications. This cam could use more compression, about 11.0-1 is supposed to be what it likes, so a change to a 0.030 head gasket next time the top end comes apart is in order.
Max HP: 96.21
Max TQ: 80.45
Model: 2002 Hugger
Cylinders: 883 bored to 1200 at HD dealer
Heads: S&S Super Stock, 2002 version (89cc chamber, 2.000 intake/1.605 exhaust valves, set up for .630 lift)
Pistons: S&S forged, 10.5-1 (matched to S&S heads)
Rocker arms: S&S roller rocker
Carb : S&S Super E (.295 intermediate, .70 main), S&S air cleaner
Intake: S&S manifold, 1.780 intake runners matched to head ports
Cam: Bob Woods W9BS (252* in/ex duration, .630 lift)
Push rods: S&S adjustable
Lifters: Stock
Ignition: Screamin Eagle Selectable Curve Race Module (Dyna2000i), curve “4”, VOES connected
Exhaust: D&D Fat Cat, perforated “Big Bore” baffle (2.5” dia.)
Cold Cranking compression: 200 front, 195 rear
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Old 28th November 2018
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Congrats on the nice result! That'll get it done!
Click Here to Contact Me
