0 Gear indicator missing
Last Post: Shahyaan
0 Transmission drain plug
Last Post: mvent
0 Indicators not flashing
Last Post: IronHeadRon
0 1975 Sportster
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
ironhead, oil pump, xlch
Old 24th April 2020
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond repute
It can be done without coming completely out of the frame , but it takes 3 guys and it really helps if the heads are off.
From your description I suspect a sheared drive pin in the feed side of the pump.
It has nothing to do with the check ball. Do not modify the check ball spring EVER.
It's not a car oil pump ,that is not a bypass , you will not raise the oil pressure by
stretching that spring only starve the engine of oil.
Old 27th April 2020
XLXLXL XLXLXL is offline
Sportster/Buell Year: 1973
XLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud ofXLXLXL has much to be proud of
Originally Posted by doodah man View Post
Check valve! Ball valve is something else - plumbing stuff.
noted this, thx
engine mounts removed, the engine can tilt enough to clear the pump without pulling engine but if you do, now's the time to mod the frame. there are several ways and many here have done so, self included.
there are a couple of other things that can be done but NOT for the faint of heart.
I see. Will check for more of this, I 've hear people creating cut off, will check for best practice. But if you could point out good resource, links, site, that will help. thx
luckily it is not that sheared drive pin. I primed the oil, bled off the air from the system. whew... I was thinking worse..
