0 Gear indicator missing
Last Post: Shahyaan
0 Transmission drain plug
Last Post: mvent
0 Indicators not flashing
Last Post: IronHeadRon
0 1975 Sportster
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
stem, superglide compatibility, xlch
Old 2nd September 2020
staniel's Avatar
staniel staniel is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: XL1200CX
Sportster/Buell Year #2: 2019
staniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to all
Default What size stem on 1972 XLCH
I have a 1972 XLCH frame that has been raked for an 8 over fork. I found a guy selling an FXE Superglide front end that I would love to buy, but I don't know if it will fit.
In my understanding the Superglide was basically a big twin motor with a Sportster front end.
I believe the XLCH is made to fit a 7/8" stem, but I'm not certain. Is that the correct size?
Does an FXE have a 7/8" stem or is it a 1" stem?
Hippysmack's Avatar
Don't know the valve stem size.
But looking at the wheel interchange page, 73-up FX models did use the same wheel assemblies as Sportsters.
http://sportsterpedia.com/doku.php/t...wheels01#front
staniel's Avatar
I guess I should clarify that I'm asking about the steering stem size.
Old 3rd September 2020
Hippysmack's Avatar
That's on me. I should have paid more attention.
I can't tell if FX will fit as the part numbers are different.
I don't know the size of either.
Old 4th September 2020
bobber58 bobber58 is offline
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to all
The Sportster has the 7/8. The FX should have a longer 1" stem. You could either get adapter bearing cups, or find a Sportster lower tree. The FX front end may be 2 inches longer in the tubes as well.
