0 Indicators not flashing
0 Gear indicator missing
Last Post: mrmom9r
0 1975 Sportster
Last Post: IronHeadRon
0 Transmission drain plug
Last Post: mvent
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
compression, xlch
  #151
Old 2nd September 2021
Dukegonzo Dukegonzo is offline
Sportster/Buell Year: 1973
Dukegonzo is an unknown quantity at this point
So I’ve got the top end torn down. My machinist is taking a look at the heads and I’ve got a set of used cylinders that I’m gonna give the stroker treatment to and fit them to my existing stroker pistons. I’ve decided instead of brazing the old returns, I’m going to use extreme heat JB Weld made specifically for metals, including cast iron.
In the meantime, I looked into the crank about a week ago and siphoned near half a bottle of oil out of the sump (approx. 400ml). Just looked in there today and it’s all drained back into there. Leaking check ball valve? What to do here? Open to suggestions.
Also what rings to you guys recommend I order
JWNathan JWNathan is offline
Sportster/Buell Model: 1200 chop
Sportster/Buell Year: '94
Sportster/Buell Model #2: XLCH 74"
Sportster/Buell Year #2: '72
Other Motorcycle Model: Most of a Shovster
Other Motorcycle Year: '65
JWNathan is an unknown quantity at this point
What about driving some thin wall tubing down the drain hole far enough to block off the old not well brazed holes?
-Jesse
Oops, missed the post that said they’re cracked.
-Jesse
Yeah, if it weren't for the cracks I was going to attempt this. I've read that a few people on here have used epoxy instead of brazing with success. Did some research and the best epoxy I've found is this right here -
https://www.amazon.com/J-B-Weld-3790...02983505&psc=1
