5 How do I increase sag ?
Last Post: andy2175m4
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 18th April 2021
Pauda Pauda is offline
Sportster/Buell Model: Xlh883 (1200)
Sportster/Buell Year: 1986
Pauda is an unknown quantity at this point
Default Oil pressure stays up 20min after shut of
Hi
I have 86 xhl 1200 conversion. I noticed that two of my lifter housing was leaking. Because of my cylinders was in the way the entire top end had to come off. So I put new seals and gaskets in top end and put together again. I just ran it on starter with plugs out. The oil pressure light switches of emeditly but takes 20min to come on again. Checked that there is oil returning to tank when running with starter.
Is this something to be worried about?
Or just a bad pressure switch maybe?
Thankful for help
Best regards from Sweden
Old 18th April 2021
rocketmangb's Avatar
Theres a check valve in that circuit but im not sure where
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 18th April 2021
Hippysmack's Avatar
I'm not sure if this is the direction of your question, but..
On cold startup, the oil will be thicker and the pressure at the switch will be higher.
Expect 60-100 psi on cold startup.
The switch is spring activated.
When high pressure hits it, the spring acts slower to retract.
It should return to normal as I imagine most do.
The fact that it does open and close is what it should do.
I tested my pressure switch and found that to be true. Results here.
http://sportsterpedia.com/doku.php/t...:ref:svcproc30
I made up a rig and initially let too much pressure hit the switch and it reacted in that way.
Old 19th April 2021
Thanks. That's was kinda what I wanted to know. My main worry is that I maybe have to high oil pressure due to blockage or something.... since I got that lifterhouse leakage and now the oilpressure switch acting pretty weird. I also but an big oil filter from a big twin on and worried about if that doesn't work properly.
Having lots of motor trust issues at the moment : )
Old 19th April 2021
Hippysmack's Avatar
You can rig up a pressure gauge off the filter pad to help settle your pressure worries.
(or the tappet hole plug on 86)
Here is the Sportsterpedia page on installing a gauge.
http://www.sportsterpedia.com/doku.p...talk:ref:oil15
Oil switch can act weird if the wire hooked to it is loose also.
You have oil returning so you have flow. That's the biggest worry, no flow.
Pressure will be high on cold startup, then the oil heats up and you'll see pressure dropping.
Here is some information on the oil switch.
http://www.sportsterpedia.com/doku.p...ressure_switch
Expected oil pressures here.
http://www.sportsterpedia.com/doku.p...talk:ref:oil04
Old 19th April 2021
juzyHD's Avatar
juzyHD juzyHD is offline
Mine does exactly the same since I have it (more than 10 years). Never had any oil related issues.
Old 22nd April 2021
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
There has been some concern with using a big twin oil filter on a Sporty. If its for an Evo big twin its ok. Something about the oil pump on twin cam big twins having more pressure. Evo engines run a 30 micron filter. The twin cam can get away with a smaller micron rating due to the oil pump. Theoretically if you run a smaller micron rating but they filter as bigger it should be ok as there is more filter media. How much bigger is the unknown factor. A lot of the guys on the Bad Weather Bikers forum (Buell enthusiasts) seem to have no issue with running a filter for a small block Ford.
Sent from my LM-G900TM using Tapatalk
Better to die on your feet than to live on your knees.
Old 22nd April 2021
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Sportster/Buell Year #2: 1981
Other Motorcycle Model: FXDC
I have heard sportsters should stay away from the 5 micron filters. Too restrictive
Just hearsay though.
Steve
'03 1250 NRHS stage two Lightning heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
Old 22nd April 2021
Hippysmack's Avatar
We know a Sportster gerotor oil pump will make 60-100 psi on cold startup.
Even if the filter is more restrictive, wouldn't that just simply raise the pressure between the pump and filter a little?
Hot oil is either gonna flow thru the filter or bust the feed line?
The flow just can't sit there if the filter blocks the path.
I'd think the pump would win that battle.
Old 22nd April 2021
Steve9's Avatar
Hippy,
Can't argue that. You're points all correct.
More restriction may reduce flow volume is what I'm saying, although it might not matter anyway
I can't remember where I picked-up that hearsay.....would be nice if someone chimed in
