0 Indicators not flashing
0 Gear indicator missing
Last Post: Porkchop9
Last Post: fafcpa
0 1982 rubber oil hoses
Last Post: Gravitas
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
0 75 XLH Bendix Carb Spitting Gas - Video
Last Post: jibber
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
2007, battery change, removal, security siren, sportster
Old 26th May 2021
Bikervation's Avatar
Bikervation Bikervation is offline
Bikervation is an unknown quantity at this point
Default security siren removal 2007 sportster
Hi all, I want to replace the security siren PP9 battery but can’t find any understandable instruction to taking the unit off. I don’t find the workshop manual at all clear (pg 7.39 . . . gently pry up on two tabs) and don’t want to break any tabs so thought I would ask here. Also once I’ve discovered how to get the alarm off I’m going to make a video of the procedure as I can’t find one. Hope you all can help - Thanks
