0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 16th June 2021
Mr.Rowdy's Avatar
Mr.Rowdy Mr.Rowdy is offline
Mr.Rowdy is an unknown quantity at this point
Aaron responded and suggested to save money and reuse the old cam gear, buy one tool and it will end up cheaper and retain the factory tolerance, so I guess that's what I will do, as well as try to be more patient. That dude is solid and quick to respond. Thanks for the input also folks. I appreciate it.
Old 16th June 2021
Hippysmack's Avatar
Max, question. Are there no worries with an impact wrench transferring torque to the wheels?
Old 16th June 2021
rocketmangb's Avatar
I wouldnt sweat it coming off,going on is a whole different thing
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 16th June 2021
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Other Motorcycle Model: FLHRI
No, the little blows of the impact hammer mech don’t make for any big rotational force. It just zips the nut off.
You could use a battery impact too.
I’m quite sure the nut could be tightened with an impact, without scissoring the crank, but there is no way to know how tight it is. (So NOT recommended).
“Smooth roads, Blue skies and Green lights”
Old 16th June 2021
Hippysmack's Avatar
Thanks, I wonder about little things like that.
I zipped the bolt loose from my Kawi primary but the last time I used an impact, I hammered, seems like forever, on a cab bolt on a C-10.
Guess that last bolt was all I remembered.
Old 16th June 2021
Sportster/Buell Year #2: '03
while you wait for the grindlock.
