Last Post: handa700
Last Post: d10221
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 need help with 68 XLH
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
Old 24th August 2021
crfblur crfblur is offline
Sportster/Buell Model: Roadster XL1200
Sportster/Buell Year: 2019
crfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud ofcrfblur has much to be proud of
Default Current Screaming Eagle Cams? What is still available?
Forgive the newbie; have a Roadster on the way and I'm already thinking about motor performance. I found some older posts showing several SE cams as current, including going back to the Andrews N4 equivalent. However, looking in the catalog only the "585" cam is still available? Who qre best dealers for HD parts?
Thanks in advance
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
Check out Newcastle HD website. If ya know the part number you can order it. I got 575 cams several months ago. Sometimes ya can find various cams on ebay.
Sent from my LM-G900TM using Tapatalk
Better to die on your feet than to live on your knees.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
http://www.hammerperf.com/xlvalvetrain.shtml#Camshafts
