0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 23rd June 2006
chrishajer's Avatar
Sportster/Buell Year: 1988
Originally Posted by Cookiey_Man
Engine oil should be at normal operating temperature (230ºF/110ºC) for an accurate reading
Whoa! HD says normal oil operating temperature is 230ºF? What about everyone who's running cooler than that? 98% of the responses were under 230 degress.
Ron, these motors rely on volume not pressure. Yours is fine. Now that you have a baseline for your motor, watch for changes, up or down.
I'm with CBAS5: no gauges for me means less worry.
--Chris
Old 23rd June 2006
chrishajer's Avatar
Yeah, the 100 PSI gauges are really useful!
--Chris
Old 23rd June 2006
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
That's probably because I learned it from you.
2005 XL1200C
Those who trade liberty for security have neither.
Old 23rd June 2006
LordVngr's Avatar
LordVngr LordVngr is offline
Sportster/Buell Model: XL1200RS Phantom
Other Motorcycle Model: Kawaski KLX250S
LordVngr is on a distinguished roadLordVngr is on a distinguished roadLordVngr is on a distinguished road
Nice writeup and pics dude. Personally I like oil pressure gauges. I guess the one thing that comes to My mind when I see the pictures is, How do you keep your engines cases so clean cause those are some Clean Cases man.
LV
Lord Venger / 05 1200R / Chopper Blue Pearl / All The Goodies
Old 24th June 2006
dodgenbullets's Avatar
dodgenbullets dodgenbullets is offline
Sportster/Buell Year: 06
Other Motorcycle Model: yamaha wr426 offroad
dodgenbullets has disabled reputation
You never cease to impress me. I have that same guage and i'm working on a mount for it. I'll let you know how it turns out.
Old 24th June 2006
Swankster's Avatar
Swankster Swankster is offline
Master Bike Builder
Sportster/Buell Model: Nill
Swankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the rough
Excellent Mr. T, as usual...
My Indy has been working on a mount for mine for quite some time now. I have not been in to much of a hurry or pressuring him, thus far; but am starting to get a little anxous. The plan is for a custom dual gauge mount near the bars and off-centered with the speedo that will hold both the oil gauge and the 2 5/8" Autometer Tach.
Jeeeezz!! after looking what you did, it seems pretty darn easy and I'm now thinking of manufacturing my own mount.
Thanks for the inspiration.
Swankster
"Stop Global Whining"
"Life, Liberty and the Pursuit of Anyone Who Threatens It"
"A Dead Enemy Is A Peaceful Enemy - Blessed Be The Peacemakers"
Still BIKELESS & hating Life!
Old 24th June 2006
AeroSport's Avatar
AeroSport AeroSport is offline
Sportster/Buell Model: 1200 XL Roadster
Sportster/Buell Model #2: 8830XL
Sportster/Buell Year #2: 2005
Other Motorcycle Model: XLS Roadster
Other Motorcycle Year: 1980
AeroSport has disabled reputation
Nice writeup and great pics, Ron, but I have a question if I may. Why did you mount the Oil pressure sending unit at the 90 degree junction of the T instead of the vertical as is was mounted originally? Was there not enough room to mount it straight down? Seems if you had done it that way it would have been easier to get to if you ever had to change it and you wouldn't have had to legthen the wire. Maybe the pics are deceiving but it looks like there would have been enough room.
:sporty:
[B]2007 1200XL R [/B] :tour
[I]RB Racing 2:1/ Mini Max/Power Vision / Dyna FXDX cartridge forks/13.5" Ricor IAS /Willwood/EBC front brakes/Lyndall Metal Matrix rear and much more[/I] :usaflag
Old 24th June 2006
ted's Avatar
ted ted is offline
Senior Master Bike Builder
Sportster/Buell Model: 883-1380cc hot rod
Sportster/Buell Year: 87
Sportster/Buell Model #2: wife's 883-1200
Sportster/Buell Year #2: 87
ted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to behold
My pressure gage is taking the oil tank cap off and looking at the return flow. Thats all that really matters.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
Old 24th June 2006
Your the man. Looks kick ass. I took a nylon spacer and cut it at an angle. My guage tilts rearward with that between the guage and bracket.
Old 24th June 2006
Turbota's Avatar
Turbota Turbota is offline
With that new silver fitting now installed into the engine case, there is just no room to mount the sending unit pointing straight down. Only place to mount the sending unit is in the horizontal and pointing to the left.
The small fitting that the stainless hose attaches to can be mounted pointing down because it has a 45 degree bend in it and it is also shorter than the oil pressure sending unit.
04 XL 1222R
