5 How do I increase sag ?
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 24th March 2010
skeith5's Avatar
skeith5 skeith5 is offline
Sportster/Buell Model #2: IRONHEAD
skeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of light
Exhaust: Vance and Hines Big Radius
Intake: Harley Heavy Breather
Tuning: SERT
Old 5th June 2010
chickenhawk's Avatar
chickenhawk chickenhawk is offline
Sportster/Buell Model: XL883R
chickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura about
2007 883R
-SE Stage1 air
-Cycle Shack slip-ons with baffles
-Xied’s
-No remap
Old 5th June 2010
ReddTigger's Avatar
Stock 2007 883
NRHS HURRICANE Air Filter
V&H Straight Shot SLIP ON
Custom MAP using Screamin Eagle Super Tuner
States I've Ridden in
71.3 hp 70.8 tq
Old 4th October 2010
bertiebettle's Avatar
bertiebettle bertiebettle is offline
Sportster/Buell Model: 1200 Nightster
bertiebettle is an unknown quantity at this point
2009 XL883L
Desperado air cleaner and modified stock pipes
4th gear, 95 RON fuel
2009XL883L
Accel SLM auto-tuner, Desperado air cleaner and modified stock pipes
Last edited by Folkie; 5th May 2012 at 19:25.. Reason: Removed superfluous xml tags
Old 3rd July 2011
iron bjorn iron bjorn is offline
iron bjorn is an unknown quantity at this point
60.4HP 76NM torque
stock engine, torque hammer 2-1 exhaust, big sucker, twin motorcycles tune
Old 5th May 2012
terroristone's Avatar
terroristone terroristone is offline
terroristone is an unknown quantity at this point
S&S style Air filter, V&H short shots. Print out shows before (dealer dyno) vs after
T1
Old 4th August 2012
HandOverFist's Avatar
Sportster/Buell Model: 1250-X
Default 2007 883l
2007 883L
Hellcat turbo @ 14psi
larger injectors
bonestock internals
Old 30th August 2012
Mental2's Avatar
Mental2 Mental2 is offline
Sportster/Buell Model #2: sportster
Sportster/Buell Year #2: 1979
Other Motorcycle Model: suzuki gs1000
Other Motorcycle Year: 1980
Mental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really niceMental2 is just really nice
2005 883 sportster
50.59 hp
48.63 torque
all ive done is
screamin eagle air filter ,rejetted the carb
vance and hines short shots
2005 sportster
1980 suzuki gs1000
Old 20th December 2012
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
2007 XL883
Bone Stock - 8,xxx miles on the clock
Click Here to Contact Me
aswracing's Avatar
2007 XL883 (same bike as the one in the previous post)
Torque Hammer Exhaust from Twin Motorcycles
Air Hammer air cleaner
Tuned with TTS Mastertune
