0 Gear and brake linkage
0 Oil pressure switch
0 need help with 68 XLH
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
Old 22nd September 2013
Fantome Fantome is offline
Sportster/Buell Model: Iron
Fantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud ofFantome has much to be proud of
HP: 99.91
TQ: 80.93
ENGINE: 2013 XL883 to SE 1200 Stage II
LOWER END: Stock
CYLINDERS: SE Big Bore Kit 1200
PISTONS: SE 10:1 CR, forged, dished
HEADS: Stock 883 w/Baisley High Performance SuperStock porting/valve job
CAMS: SE .575
EFI: SE Super Tuner
AIR FILTER: Hammer Performance Air Hammer 2"
INTAKE: Stock w/Baisley High Performance porting
EXHAUST: D&D Bobcat 2:1 w/Concentric Baffle
CLUTCH: Stock w/SE spring
TRANSMISSION: Stock 883 gearing
Old 11th January 2014
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
2007 883 with the following mods:
Stock 2007 XL1200 heads
Stock XL1200 cylinders & pistons
Stock "W" cams
HAMMER PERFORMANCE "SLEDGE" Air Hammer Air Cleaner
Patriot Defender Exhaust
Dynojet Powervision
Click Here to Contact Me
Old 20th March 2015
doomedcobra's Avatar
doomedcobra doomedcobra is offline
Sportster/Buell Model: XL883N Iron
doomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to all
2011 XL883N Iron - 71hp 75tq
CYLINDERS: stock XL1200
PISTONS: stock XL1200
HEADS: stock XL883N
CAMS: stock XL883N
AIR FILTER: SE Heavy Breather
EXHAUST: Cycle Shack drag pipes, not modified
CLUTCH: 1200 spring
Tuner: TTS MasterTune
Remove some stuff. Add some stuff. Rinse and repeat.
Old 30th October 2016
scott45acp's Avatar
scott45acp scott45acp is offline
scott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to beholdscott45acp is a splendid one to behold
ENGINE 2009 883 with S&S 883 to 1200 kit
LOWER END: Stock
CYLINDERS: S&S
PISTONS: S&S Forged reverse dome conversion (supplied with the kit)
HEADS: Stock 2009 883
CAMS: Stock
AIR FILTER: SE air cleaner W/K&N filter. ham can cover
EXHAUST: Python slip ons
CLUTCH: Barnett extra plate kit w/ HD 1200 diaphram spring
TRANSMISSION: Stock with 883 pulleys.
Tuned by Fuel Moto with PowerVision
-----Other hobbies--------
Salt water reef aquarium
Pistol league
Mentor for high school FRC robotics team
Old 21st November 2018
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant future
Max HP: 96.21
Max TQ: 80.45
Model: 2002 Hugger
Cylinders: 883 bored to 1200 at HD dealer
Heads: S&S Super Stock, 2002 version (89cc chamber, 2.000 intake/1.605 exhaust valves, set up for .630 lift)
Pistons: S&S forged, 10.5-1 (matched to S&S heads)
Rocker arms: S&S roller rocker
Carb : S&S Super E (.295 intermediate, .70 main), S&S air cleaner
Intake: S&S manifold, 1.780 intake runners matched to head ports
Cam: Bob Woods W9BS (252* in/ex duration, .630 lift)
Push rods: S&S adjustable
Lifters: Stock
Ignition: Screamin Eagle Selectable Curve Race Module (Dyna2000i), curve “4”, VOES connected
Exhaust: D&D Fat Cat, perforated “Big Bore” baffle (2.5” dia.)
Cold Cranking compression: 200 front, 195 rear
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Last edited by Folkie; 22nd November 2018 at 00:13.. Reason: Removed surplus img tags
Old 22nd November 2018
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Just a reminder: posts with dyno charts only; no comments or chat here please. Other posts will be deleted. Comments and questions about the dyno charts posted here can be posted in a separate thread in the Dyno Charts And Results section. Thanks.
Folkie
South East England Riders
