Last Post: handa700
Last Post: d10221
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 need help with 68 XLH
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
Old 18th May 2007
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Default Dyno Chart Reference: 1250 (all 1250 conversions: 883-1250, 1200-1250)
Here's where to post your dyno charts for 883 → 1250 and 1200 → 1250 conversions.
Please read these instructions before posting here.
The instructions include an example post of what what your post should look like.
Folkie
South East England Riders
Old 27th May 2007
jessearias's Avatar
jessearias jessearias is offline
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 1984
jessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nice
ENGINE: 2002 1200S
LOWER END: Stock
CYLINDERS: Axtell Cast Iron 1250
PISTONS: 10.5-1 Forged w/ 15 degree domes (supplied with 1250 kit)
HEADS: Buell Thunderstorm w/ NHRS Stage I porting, Dual plugged, Guides cut down to accept .600 lift cams, HD springs and retainers
ROCKERS: Stock
PUSHRODS: NRHS fixed .040 shorter
LIFTERS: New stock replacements from Comp Cams
CAMS: SE .536
CARBURATION: Mikuni 42 mm w/ Yost power tube , 170 main, 25 pilot
AIR FILTER: NRHS Hurricane 2" w/ stock ham can cover
EXHAUST: Rich Products Thunderheader
IGNITION: Daytona Twin Tec Model 2005 w/ VOES hooked up Custom map, 32 degrees total timing, switches set SELECT 7, SLOPE 5 (note that these switches are disabled with the custom map)
COILS: Two Dyna DC1-1 mounted with a Rivera Engineering coil bracket
CLUTCH: Barnett extra plate kit w/ Barnett HD diaphram spring
TRANSMISSION: Stock
OTHER MODS RELATED TO ENGINE: Pingel High flow petcock, Balance Masters crank and clutch basket balancers, .030 Cosmetic head gaskets, .020 base gaskets, Denso IXU24 plugs
COMMENTS: None
[FONT="Arial"] Jesse :smoke [/FONT]
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
Old 28th May 2007
Piggy's Avatar
Piggy Piggy is offline
Other Motorcycle Model: Dyna Street Bob
Other Motorcycle Year: 2007
Piggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enough
Engine: 2005 883
Cylinders: NRHS 1250 conversion, iron lined aluminum
Pistons: 10:1 reverse domed pistons
Heads: stock 883
Cams: stock 883
Air filter: SE
Exhaust: SE II slip ons
Ignition: SE 1200 pro
Carb: Dyno jet kit 45/170 jets
Spark plugs: NGK DCPR9E (2 stock numbers colder than original plugs)
Now running Yost power tube, 45/190 jets and waiting on cables to custom map my TC88A ignition, getting some pinging once in a while with the SE 1200 pro ignition. Tried the TC88A with settings at 0 initial timing and 0 slope (complete minimum settings) and still get a little pinging.
Runs hot on highway at 70-80 mph with oil temps 250-260. Oil temps at idle about 220-230.
Current bike: 07 Street Bob
V&H Short Shots, SE air cleaner, Power Commander, forward controls
Previous bike: 2005 Sporty NRHS 883/1250C conversion AKA oil guzzler R.I.P
Old 18th June 2007
tonyhds's Avatar
tonyhds tonyhds is offline
Sportster/Buell Model: NRHS 1250 C
Other Motorcycle Model: Road King Classic
tonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of light
Default 04 883c
HP 82.3 - Torque 78.
NRHS 1250 cylinders
Flat top pistons 10.5- 1 CR
NRHS Stage 2 883 heads
Daytona Twin Tec
SE 497 cams
SE II's slip ons
SE air cleaner
04 Road King Classic
04 NRHS 1250 Custom - Longhorns Orange
10.3-1 Flat tops, Stage 2 heads, Powdercoated black w/ highlighted fins, SE 497 cams, TC88A ignition w/ a custom Map, 2" HurricaneFlow intake, 1200 gearing, Energy One clutch, Progressive 418's and Progressive front springs, Mustang Vintage and loves oil.
aka " The Guzzler "
" A song needs to breathe. The rhythm needs to breathe. Sometimes the best way to get some punch out of something is to slow down right before you hit it. Kind of like a slingshot --- Pow "
SRV
Old 29th August 2007
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant future
Talking Messed up the pict...
Ooops,
I must have used the wrong photo bucket link in previous reply.
Here is my chart I hope.
-Y2K or 2000 883 XL. Black of Course.
-1250 Jugs with 8cc reverse dome conversion pistons.
-HSR 42 Mikuni Carb.
-25 Pilot 172.5 Main 96 Richer Jet Needle, 3rd clip down I think.
(Actually fixed a fuel starvation that others diagnosed as reversion)
-07 SE HEAVY Breather. Similar to Forcewinder.
-Adjusted V.O.E.S.
-Vance and Hines Straight Shot Exhaust w/Baffles.
Every thing else engine wise is stock.
Still researching for different heads and cams to create a TQ monster.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Old 28th October 2007
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
just for comparison here's mine after a stage3 head porting and SE.575 cams, mikuni 42, but still the V&H pipes it had as an 883, albeit the valve guides were seriously leaking oil into the combustion chamber at the time and I'm unsure if that skewed the numbers.
Chris
My Other Toy Goes Mach 25
Old 1st July 2009
OmegaRunner's Avatar
OmegaRunner OmegaRunner is offline
Sportster/Buell Model: 883/1250 XL
Sportster/Buell Model #2: Blast (wife's bike)
Sportster/Buell Year #2: 2002
OmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really nice
Max Power:77.04
Max Torque:82.16
BIKE: 2003 XL883
ENGINE: 2003 883
LOWER END: Stock
CYLINDERS: NRHS 1250
PISTONS: supplied with 1250 kit, flat top
HEADS: 883 NRHS competition valve job, relieved chambers
ROCKERS: Stock
PUSHRODS: Stock
LIFTERS: Stock
CAMS: SE .497
CARBURATION: Stock
AIR FILTER: SE
EXHAUST: SE 2-1 w/ baffle removed
IGNITION: SE 1200
COILS: SE
CLUTCH: Stock
TRANSMISSION: Stock
OTHER MODS RELATED TO ENGINE: Jaggs oil cooler
Old 26th February 2010
gjukema's Avatar
gjukema gjukema is offline
Sportster/Buell Model: Sportster Hugger 883
Other Motorcycle Model: DRZ-400E
gjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to beholdgjukema is a splendid one to behold
Thumbs up 2002 Hugger NHRS 1250
ENGINE: 2002 883/NRHS 1250
LOWER END: Stock
CYLINDERS: NRHS Iron-Lined Aluminum 1250
PISTONS: 10.1 dished (supplied with 1250 kit)
HEADS: Stock
CAMS: Stock
CARBURATION: Stock CV w/ Thunderslide kit
AIR FILTER: SE
EXHAUST: SuperTrapp Slipons
IGNITION: Stock - retarded
TRANSMISSION: Stock
COMMENTS: Essentially, this is a stock 2002 883 Hugger top-end with the NRHS 1250 kit. The original owner had the Thunderslide kit installed.
2002 883 Hugger (raised), Hammer 1250 (Winter 2015/2016), Hammer 2" offset air cleaner, SuperTrapp 2:1, Stage 2 Light 883 heads, N4 Cams, Cafester (2012/2016).
Old 21st April 2010
dshef007's Avatar
dshef007 dshef007 is offline
Sportster/Buell Model: sportster 883-1250
dshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to alldshef007 is a name known to all
HP: 85
TQ: 77
PISTONS: NRHS FLAT TOP 10.5-1 CR
CAMS: ANDREWS N4's
HEADS: NRHS 883 STAGE II
AIR FILTER: NRHS HURRICANE 2"
EXHAUST: STOCK HEADERS / CYCLE SHACK TURNOUTS
IGNITION: ULTIMA
CARB: STOCK CV, 145/180, .040 NEEDLE SHIM
COMMENTS: added Samson Caliber pipe over the winter, will dyno it soon to see the difference, butt dyno feels much stronger in the bottom end.
Samson Caliber 2-1, Hurricane Air Cleaner, Ultima Ignition, Accel wires, NRHS 1250, NRHS Stage II 883 Heads, Hurricane Flat Top Pistons, 10.5 CR, Andrews N4 Cams.
Old 2nd June 2010
barry jubber's Avatar
barry jubber barry jubber is offline
Other Motorcycle Model: T140 Triumph Bonneville
Other Motorcycle Year: 1981
barry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to behold
Power:100.47 Torque: 115.22
Bike: 2006 XL1200C
Cylinders: 1250 NRHS
Pistons: Supplied by NRHS
Heads: NRHS Stage 2 light
Compression Ratio: 10.5:1
Rockers: SE Roller
Pushrods: Hurricane
Lifters: SE
Cams : SE 536
Carburation: Mikuni HSR42
Air Filter: HD Heavy Breather
Exhaust: SuperTrapp 2 into 1 tunable
Ignition: Daytona Twin Tec
Clutch: SE
Plugs and Cables: SE
Oil Cooler: HD
