5 How do I increase sag ?
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
  #31
Old 25th April 2013
Gcram399's Avatar
Gcram399 Gcram399 is offline
Here's the link to Phillober's build. Although he's doing a full conversion in his thread, you can just follow the posts where he removes the rocker covers to relieve the pressure on the pushrods without removing the rocker arms or the heads.
It's an exceptionally good thread with lots of excellent photo's and explainations. It walks you through the entire process. In my opinion it's better than any one person can explain in type.
Click here. http://xlforum.net/forums/s....php?t=1122547
George
--Thomas Jefferson
Old 25th April 2013
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Originally Posted by MEMECH View Post
Im in the same bat as grfktatoo , cams came of doing a simple cover swap and cams where nor alligned, dont know the position the pistons where and bike was moved a bit , dont know where to go about at this point, any ideas?
Thanks
Also a reference here.
Click Here to Contact Me
Similar Threads
pics of my 1st complete build lucky13 Chopper & Bobber Talk 61 30th September 2017 18:04
04-05 Cam Install How-To with pics just posted: Turbota Sportster Motorcycle Motor - Top End 9 19th October 2007 01:07
Pics of my roadster - winter projects complete! Gone Sportster Motorcycle General Discussion and Problems 21 10th March 2005 01:06
anyone install a hypercharger on a 04 1200? vetthed Rubber Mount Sportster Motorcycle Talk (2004-2006) 15 7th March 2005 13:47
FXSTB 'Night Train' SE Aircleaner Install (pics) Turbota Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 15 26th November 2004 02:06
