0 Sportsterpedia Progress
0 clutch spring compressor
Last Post: Yakcm2
Last Post: CMCSSeabee
0 520 conversion for ironheads
0 my rear wheel
0 oil feed line between pump and filter
0 Friction modifiers in gasoline
0 3.3 gallon looking tank that's 4.5 gallon or more
Last Post: sglock45
0 Your Motorcycle Workspace/Garage
Last Post: hbsporty
0 Delete rocker box breathers or not?
0 Trackiing/data mining tactics.
Last Post: Dan78
0 loose exhaust
Last Post: stikflote
0 Thunderstorm heads &1200 barrels
0 math problem, piston rings
Last Post: thefrenchowl
4 Another Bogan from the South Seas
Last Post: RKN
0 Adding fuel level sensor to the speedo/tach
Last Post: Firehawk
0 Rubber mount parts that fit a rigid mount?
0 Tires!
0 Filling stock motor mounts with liquid urethane
hillclimber (70), burtondl2 (52), Cet (50), hagar71 (49), ShaneWolfe (48), grizdiesel (43), Confused89 (35), RAIDER0372 (34), spamer80 (34), svwannabe
Old 16th August 2015
Haegar Haegar is offline
Haegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud of
Default Conversion RWHP to Crank HP ?
Hi,
I'm Chris from Germany and a I have a question to the Dyno Specialists here.
Yesterday I put my modified 883/1200 on a Dyno. The resulst are :
73HP at 6200RPM and 81lbs/ft at 3000RPM (very nice to ride ;-) ).
These are the values at the rearwheel. There was a little computer problem and it was not possible to make the correction. Does anybody knows, how many hp this could be at the crank ?
Thanks and greetings from Germany
Chris
Old 21st August 2015
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Im guessing add about 15% give or take a bit.
squekster's Avatar
squekster squekster is offline
Sportster/Buell Model: 883/1200 conversion
squekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud of
Originally Posted by Haegar View Post
Hi,
Chris
Try this;
http://www.mk5cortinaestate.co.uk/calculator4.php
I agree with Madnss. Add about 15%.
