0 spark plug wire ohms
Last Post: burely
0 2.18 Gearing Ratio For 5 Spd 1200??
0 Alarm Time Out?
Last Post: brixtonanima
0 Finding an accessory power source
0 Finally Got the Kinks Out
Last Post: JackPrice53
0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 Head bolts and conversion
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 Swingarm bearings - boy I'm glad I looked at them
Last Post: Scott
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
Last Post: Proteus
0 '86 1100 basket build
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
0 su carb question
0 Touring on a Hugger
basket, clutch
Old 7th January 2016
juzyHD's Avatar
juzyHD juzyHD is offline
Senior Bike Builder
Sportster/Buell Year: 1986
What sort of material are you planning to use for the sleeve?
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year #2: 1994
Mild steel
Sent fra min HUAWEI Y560-L01 via Tapatalk
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
juzyHD's Avatar
Senior Bike Builder
What about any type of hardened aluminium? Trap door is aluminium, isn't it?
what about outer diameter of the sleeve the '4'- 63,5mm( you marked it '3' but you probably mitsaked.?), is that the diameter of trap door hole or the sleeve must be that wide?
norseXL's Avatar
Alu should work to with good press fit.
Yes it should be 4 not 3 and I could not get a good measure on that hole but it was close to2.5 inches, but you would have to make a precise fit for it so take your own measurements
Old 14th January 2016
juzyHD's Avatar
Senior Bike Builder
Hey norse! I just want to let you know that I foud NUP1009 roller bearing (6009 replacement) bearing on Alibaba if you are interested!
norseXL's Avatar
Thx, but my SKF 6009 is still good
and with the support bearing it should be no need anyway...
Tore
Old 20th January 2016
juzyHD's Avatar
Senior Bike Builder
Hey norse! What's the progress?
I'm just wondering, I send some inquiries for 6908 rs bearing on ebay and if it is suitable for wet primary drive. They all said that is not!? Do you think it would be better if it would be metal shielded?
norseXL's Avatar
Not much progress, waiting for tools.
Rubber should be fine, even H-D use rs-bearing in the clutch, they do however use steel-shield on the one in the trap-door for some reason.
Tore
Old 25th January 2016
Sportster/Buell Year: 1988
Hi norseXL
Nice work on the trap door! I bought a Zipper trap door in the end but I find that it is the clutch basket 6009 bearing that still fails first - the dreaded basket wobble. It is worth using loctite bearing fix on the inner hub when pressing it up and shimming out all the end float.
I have linked details of how to buy a Koyo japan made NUP1009 bearing with machined brass cage on the link: http://xlforum.net/forums/s....php?t=1434936
Mine arrived after ten days and cost £25 from NOKs bearings. NOKs had them in stock. Or you can also special order them in Europe for big money and it will take months.
If you follow my other link to the HDRCGB website you see photos and diagrams of the bearing. It is three piece design with a thrust ring so the inner encloses the rollers when pressed up. You will see it is much stronger than a 6009. It is an open design, so the oil mist lubrication should be sufficient, as is the case for the throw-out bearing, which I replaced with a more suitable SKF 7200 angular contact bearing.
I will post some feedback on how I get on in use. Hope that helps
norseXL's Avatar
Originally Posted by Four Speed View Post
Hi norseXL
Nice work on the trap door! I bought a Zipper trap door in the end but I find that it is the clutch basket 6009 bearing that still fails first. It is also worth using loctite bearing fix on the inner hub when pressing it up.
I would definetely have gone for the 1009 bearing if I had not been doing the support bearing fix,
however, with the support it is not needed.
Jepp, the angular contact throw-out bearing is a good one, I went for that myself after being stuck down-town Oslo without a clutch...
Tore
