5 How do you Wash your Bike?
Last Post: A Seabee
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: kristyza
0 Question for RB racing exhaust guys/gals
0 Robbie's uncomfortable seat theory
Last Post: robbie202
Last Post: A Seabee
0 Innovative motorsports 3918
Last Post: motorend
10 howdy from australia
0 1991 frame/engine original ground locations
0 Battery reversed, bike dead
0 Fender Fit and Shinko 270 On Rear 4.50x18?
Last Post: A Seabee
0 Rocksett
Last Post: Gone_Shootin
0 EZY Pull for '77 XLCR
0 Jumping and rocking at around 3K rpm
0 GPS Speedo?
0 Bike lost power,back fired and stalled
Last Post: zack74
0 A Mad Lad on a Blast
Last Post: Hornsmith
0 true length of after market brake cable
Last Post: don_don465
0 Cams exhaust note
0 Resistor vs Copper plug wires?
0 Show your bike next to a train
0 1985 XLX Ironhead with Hi-4N Ignition - Spark cuts out at 3500 rpm
0 Oil in air cleaner
Last Post: denguy
0 I guess I'm back
Last Post: Veeflys
0 Ride Report 2019 Black Hills, Grand Teton Mtns., Rocky Mountain Ntl. Park
Old 23rd May 2016
nleco's Avatar
nleco nleco is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1984
nleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to behold
great job !!
Sent from my Nexus 5 using Tapatalk
2009 Iron
  • 1250 Hammer Kit
  • 30 degree reverse dome pistons
  • 1.770 7MM Intake 4.520 TG Conversion
  • 1.530 7MM Exhaust 4.610 TG Conversion
  • Striker Performance 7MM Valve Spring 550 Lift Triple Grove Locks/Beehive Springs
  • Competition Valve Job
  • 560 Impact Cam Set
  • Bronze Oil Pump Gear
  • Dragtron II AC
  • V&H Shortshots
1984 Ironhead
Old 23rd May 2016
wedge's Avatar
wedge wedge is offline
Dont think you need a 100HP with Mama on the back anyway !
I don't think it would help. I just went from a docile 883 to 93 HP, and I still can't outrun her, even on a long straight.
Did I just say that out loud?
Old 24th May 2016
joel f joel f is offline
Sportster/Buell Model: 1200
joel f is an unknown quantity at this point
I have the exact parts including home ported xb heads other than I built a homemade 2-1 exhaust. Wondering where you ended up with timing and the main jet? 93 h.p. is getting it especially at that rpm, my limiter is set at 6700 and it pulls solidly right to it lol.
Sent from my SM-G900R4 using Tapatalk
Old 24th May 2016
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Originally Posted by joel f View Post
I...Wondering where you ended up with timing...?
I've had numerous PM inquiries regarding the timing map used for Wedge's project...have a look:
Old 24th May 2016
Cool thanks, I set mine at 30, probably play with it at the track to see what gets me the most mph.
Old 24th May 2016
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud of
Is there another set of blocks below map 30? The 30map is close to whats in my 03 n4'd 1200 for WOT, and it really likes it. The 20map is close to my part throttle map.
SuiCyco Racing
47L
In Honor of Charlie Roach RIP
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 24th May 2016
Rico 05R's Avatar
JESTER SYNDICATE
Originally Posted by cycowrencher View Post
Is there another set of blocks below map 30?...
No, that's the limit.
Old 25th May 2016
wedge's Avatar
Main jet ended up at 170
Pilot is 27.5
Y8 needle jet
97 needle with clip second groove from top
I always tune from the bottom up, meaning, I put a 180 in this bike to begin with while I set the idle and mid range. I started the process while this carb was on David's bike (similar setup with the same cams), and when it went on this bike it was good except for a small tweak on the mix screw. (3/4 turn by the way is where it ended up). I was going to ride it another week or so then get the main jet dialed in, but the trip to the dyno got that done right there. I always start with a huge main jet, because if you starve the mid range, then you can't get the needle right. The main jet doesn't matter until you get the mid range right. You can leave the main jet on your bench while you dial the bottom end of the carb.
I agree that mine would have pulled past the 93 mark, but I have the limit at 6200. Not sure if you read it, but I didn't want to pull the seat while we were there this time because the sissy bar is right on top of it and needs to be pulled to get the seat off.
Next time I will push it further and see where it really tops out.
We all have to hand it to Rico. He made a great map for my Roadster a long time back and that map is perfect for that bike. This map seems good, with just a lot of decal popping. (Could be tunable in the idle circuit, but I'm happy with it, so I'm not going to bother playing further with it.) Unless the plugs turn up something that I have not seen yet.
Old 25th May 2016
rocketmangb's Avatar
What main did we end up with Wedge ? 165 or 167.5 ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 25th May 2016
wedge's Avatar
on your bike we ended up with 165
Mine is 170
