0 clutch spring compressor
Last Post: Yakcm2
Last Post: CMCSSeabee
0 520 conversion for ironheads
0 my rear wheel
0 oil feed line between pump and filter
0 Friction modifiers in gasoline
0 3.3 gallon looking tank that's 4.5 gallon or more
Last Post: sglock45
0 Your Motorcycle Workspace/Garage
Last Post: hbsporty
0 Delete rocker box breathers or not?
0 Trackiing/data mining tactics.
Last Post: Dan78
0 loose exhaust
Last Post: stikflote
0 Thunderstorm heads &1200 barrels
0 math problem, piston rings
Last Post: thefrenchowl
4 Another Bogan from the South Seas
Last Post: RKN
0 Adding fuel level sensor to the speedo/tach
Last Post: Firehawk
0 Rubber mount parts that fit a rigid mount?
0 Tires!
0 Filling stock motor mounts with liquid urethane
0 How much is too much?
hillclimber (70), burtondl2 (52), Cet (50), hagar71 (49), ShaneWolfe (48), grizdiesel (43), Confused89 (35), RAIDER0372 (34), spamer80 (34), svwannabe
Old 22nd May 2016
rocketmangb's Avatar
Default Rocketmangb's Cannibal Queen 1250 build
Some left in her just gotta find it !
Did sound like the clutch was trying to go away.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 23rd May 2016
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Did you try a bigger main?
Old 25th May 2016
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
id say bigger accelerator shot and bigger main like madnss said .
