0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
Last Post: stikflote
0 Arun Floods
0 my recent ebay purchase
14 Mid controls??
0 Intake manifold
0 Black Bike Bible
Last Post: 83XLX
0 Roadster CX Cafe Build
Last Post: Otter
Last Post: Carl74
0 CV40 spacing
Last Post: Carl74
0 Lucas fuel stabiliser
0 900 heads contd..
0 my only real beef with my 03 883
Last Post: robbie202
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Harley-Davidson Sales Slump: What Next?
Last Post: brixtonanima
0 new to me 883
0 Dyno AFR and plugs on my 1275 04 Sporty
Last Post: Hellbent_4
0 Too HOT to ride?
0 Tank Paint Ideas
Last Post: MotorPete
0 Trans corner fix
cbsportster (69), sjeccles (52), 2011_Nightster (52), reeb (49), Maff (49), jl_rotary (42), UMLsilva (34)
Old 16th December 2018
95sporty1200 95sporty1200 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
95sporty1200 is an unknown quantity at this point
The bolt is one of the primary cover bolts. I thought it was missing but turns out it was broken off below the cover at one of the knock pins. Doesn't surprise me. All the fasteners I've encountered so far have been tough to get off.
JackFrost71 JackFrost71 is offline
Sportster/Buell Model #2: Help S3T
Sportster/Buell Year #2: 2000
JackFrost71 is on a distinguished roadJackFrost71 is on a distinguished roadJackFrost71 is on a distinguished road
Make sure you use antisieze grease when you're putting it back together. That's probably why you have to do an extraction in the first place.
Good luck!
Old 17th December 2018
I can't quite tell for sure - The image is a little dark - But right near the shifter shaft, it appears (in this picture) that one of the Ring Gear Teeth is missing or shorter than the rest...
Is that so?
Check Out The Sportsterpedia
Old 19th December 2018
Thanks for the tip on the anti sieze.
Good eye about the gear tooth! Unfortunately I got some cold bug that hit me pretty hard, and haven't been doing much of anything. The plan is to get some better photos, confirm the chain tensioner model, and try and remove the nut to inspect the stator. I'll see what stoud material I have to wedge the gears... Though I'll probably go and pickup the heavy duty brass hinge.
Old 22nd December 2018
Updated photos. Old tensioner it looks like. The teeth look decent enough, must've been a smudge on the lense
Another photo
And one more
With some grunting and an old door hinge was able to get the front nut off. Seemed a tad smaller than 1 1/8. Stuck at the clutch nut... Don't have 1 3/16" socket. For some reason I have (2) 1 1/8 sockets, so will grind the second one down a bit. Will get some photos once I'm in. Also need to pick up some red locktite for reassembly.
Well, 1 3/16 was way too large for the socket, so I picked one up.
Pics attached... I didn't see anything noteworthy, other than on the clutch assembly, the teeth that engage the starter look like they were hitting the shifter arm. Maybe it's these chunks that I saw in the oil?
Additional photos
