0 Leineweber camshaft
0 1980-1981 rear brake pads
Last Post: Scott
0 I'm back... Got questions for buying a nused Sporty
Last Post: Thorsteenster
0 2010 Sporty will not fire! Tried everything, HELP!!!
Last Post: kxrwcer52
0 Who runs 70wt. oil
0 what else is different on a 1200
0 Help me identify this bike
4 Starter Solenoid problem/ Blowing fuses
Last Post: Yellowstone Kelly
0 cleaning your sporty
Last Post: stick shift
Last Post: Kawa110
0 Check Engine - PCM - Battery problem
0 Your Favorite Style
0 Ironhead heads restoration and upgrade
0 Specially constructed (SPCNS) vehicle emissions certification
Last Post: Calcustom
7 Greetings from Puerto Rico
Last Post: XL48PR
0 Are you a Vet?
Last Post: Edster
Last Post: joes95bobber
Last Post: smokeybear
0 Floating front disc
0 No spark
Last Post: Another.Mike
0 What fork suspension upgrade for 2016+ sporster(49mm forks)
0 Who would you loan your bike to?
0 While the top end I’d off
Last Post: lmarshall73
0 2016 Oil Drain Hose Has Cracks
jscibello (68), Reign (61), corad (57), desertratguy2001 (56), gdice1 (42), judas (38), schruddy (36), Wrong Way (33), Crank
Old 22nd July 2018
Yes that was very informative and I understand it. Right down to the part about not getting into the transfer ports for your idle.
I'm actually pretty good where I'm at now. I'll probably try the 42 pilot tho and turn the IMS out. But I'm thinking I may have to shim the needle with the smaller pilot. It's all a balancing act. I'll probably end up back at the 180 main then too. Possibly even a 175.
Personally, I'm less concerned with the final number of turns of the IMS than I am about getting the Transfer Ports properly fueled so that the operation of the throttle plate & needle do not need to be distorted to compensate for the incorrect Transfer Port operation...
Getting the Transfer operation right with the right Slow Jet is critical - the slow jet is the only control over the fuel mix to the Transfer Ports - After getting the Slow Jet right for the Transfer Ports, THEN, adjust the IMS so the Idle Port operation works correctly with the Slow Jet you needed for the Transfer operation...
This is the reason I (and others) suggest that the 45 slow jet is usually (tho not always) better than the 42 - It makes the Transfer Ports richer - which means the throttle plate & needle can stay more closed so that the transition is actually happening on the Transfer Ports and not on the extra throttle plate opening to suck more fuel thru the needle jet...
Every engine is slightly different - so you do need to tune the carb to what the engine needs... But try to minimize opening that throttle or pulling that needle (weak spring, shims, etc.) too soon...
Good Luck...
2 Relax
Old 22nd July 2018
rocketmangb's Avatar
OK heres some weird shit !
In my collection I have a "5MAHR" needle ?
WTF ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 22nd July 2018
WTF ?
--OFF TOPIC--
CV Jet Kit (For Twin Cam models?)
Manufacturer: Slinger Airflow Werks
Part #: SAW015
Aliases: DS-195100 (Drag Specialties #)
Product Specs:
Recalibrate your stock CV carb to make the most out of the air cleaner, exhaust and cam changes or head work.
Kit contains a #5 MAHR needle, 08BOO jet holder, #45, #48 and #50 slow jets, and #190, #195, #200 and #205 main jets
Suggested jetting guidelines are included with the kit
Made in the USA
2 Relax
Old 22nd July 2018
Wonder who made it ?
Old 22nd July 2018
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Good Luck...
2 Relax
See and that's why I thought about toying with the N65A. It would/should allow me to stay/go with a bigger pilot. It would (I believe) also get into the taper sooner (shorter needle) without shimming or a weaker spring. Im thinking it may be a smoother transition. That's my thinking anyway.
Like I said I seem to be pretty good. I'm more like 1 3/4 turns on the IMS. 1 1/2 only on the super hot days of mid 90s.
Maybe put the 45 back in with this needle. I just want to be sure I have it as best as it can possibly be. I'm just not totally convinced it's there. Maybe just me being an anal perfectionist as the wife says. lol
Old 18th February 2020
npaisnel npaisnel is offline
Sportster/Buell Year #2: 1993
npaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant future
Just looking gin to all this too..got to go to work now..but putting a reply in here to book mark this thread.
I was thinking of going to a 48 idle...but maybe that is not the way...
Will get back to this later.
When you run the idle mixture screw all the way out and can't make the idle worse you need a bigger idle jet.
When you have the throttle blade positioned (at idle) where it should be so you're not pulling transfer fuel at idle you frequently need a bigger idle jet.
Slinger Airflow Werks has a jet kit for the Sportster, SAW-022 if it still exists.
