0 xlh 1000 1972 first project
Last Post: daniel91
7 Greetings from Puerto Rico
0 Help me identify this bike
0 Leineweber camshaft
0 1980-1981 rear brake pads
Last Post: Scott
0 I'm back... Got questions for buying a nused Sporty
Last Post: Thorsteenster
0 2010 Sporty will not fire! Tried everything, HELP!!!
Last Post: kxrwcer52
0 Who runs 70wt. oil
0 what else is different on a 1200
4 Starter Solenoid problem/ Blowing fuses
Last Post: Yellowstone Kelly
0 cleaning your sporty
Last Post: stick shift
Last Post: Kawa110
0 Check Engine - PCM - Battery problem
0 Your Favorite Style
0 Ironhead heads restoration and upgrade
0 Specially constructed (SPCNS) vehicle emissions certification
Last Post: Calcustom
7 Dual Disk Setups
Last Post: XL48PR
0 Are you a Vet?
Last Post: Edster
Last Post: joes95bobber
Last Post: smokeybear
0 Floating front disc
0 No spark
Last Post: Another.Mike
0 What fork suspension upgrade for 2016+ sporster(49mm forks)
0 Who would you loan your bike to?
jscibello (68), Reign (61), corad (57), desertratguy2001 (56), gdice1 (42), judas (38), schruddy (36), Wrong Way (33), Crank
Old 17th February 2020
Nicktree1200 Nicktree1200 is offline
Sportster/Buell Model: Sportster 1200c
Nicktree1200 is an unknown quantity at this point
Thumbs up Mid controls??
Hi, can anyone help? I've recently purchased a Sportster 1200c 1997.. all the 1200 custom models I've seen have slightly forward controls as standard! Mine has mid mount controls? It also says on the log book that mine is a 1200c sport? Anyone out there heard of this model? Or know if some 1200 customs came with the mid mounts?
Thanks!
harley506d's Avatar
Sportster/Buell Model: 1200c
Have a look here to see what you have,
http://sportsterpedia.com/doku.php/s..._specific_year
Cheers harley506d!!
The engines for the 1996 & 1997 Sport Models were NOT like the 1998-2003 models...
http://sportsterpedia.com/doku.php/s...ection19901999
These early Sport models were based on the XLH 1200 model plus added the features of adjustable-damping front forks, adjustable rear shocks, a slight increase in engine power due to a different igntion module and dual front floating-disc brakes...
Cheers dude!
Did you check the VIN to see whether you have the 'C' model or the 'Sport' model?
Old 18th February 2020
Yeah I did cheers!! It is the c model..I put the vin number in and it threw up a picture of a c model with mid controls! Maybe the earlier customs had these as standard and later models had the forwards?
Thanks
So I checked --- 1999 was the First Year for the 1200C models having stock Forward Controls...
Old 19th February 2020
Cheers bud, you're a star!
