Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER & BUELL MOTORCYCLE RACING > LSR - Sporster & Buell Motorcycle Land Speed Record
LSR - Sporster & Buell Motorcycle Land Speed Record Discuss Sportster & Buell Motorcycle Land Speed Record events.
0 Bean in a can (rattling when accelerating)
0 No Power to hand controls
0 New Harley CEO
Last Post: denguy
0 my local dealership closed today
0 My frist question...Fork seal replacement
Last Post: thefrenchowl
0 Knocking in Front Cylinder Until Warm (Before & After Rebuild)
0 1986 Adjustable Push Rod Adjustment
0 Fng
0 Positive news for Harley-Davidson
Last Post: Whitewalls
0 Fork oil q
Last Post: 1Scooter
0 New oil tank
0 Bowker Harley Davidson Preston
0 top end rebuild
Last Post: eisenhead
0 73 Electric Start won’t run after firing
0 newbie
Last Post: mrsunshine
0 New member
0 Royal Enfield speeding ahead in Asia
Last Post: rickxx
0 Regulator/rectifier question
Last Post: LenC
5 Is factory Stage 1 worthy?
0 Removing transmission 1973 XLH
0 Any Teamsters?
Johnc (74), x750rider (67), bart53 (67), bad rad (66), halfdrive (55), jag1 (48), Zuhaib (36)
Old 14th September 2014
Nytstr's Avatar
Nytstr Nytstr is offline
TurboMafia Charter Member
Sportster/Buell Model: XL1343NT LSR #1171/1175
Sportster/Buell Model #2: XL1250RT
Other Motorcycle Model: FXRP
Other Motorcycle Year: 1986
Nytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant future
Default Salt Rattler prepares for 2015 World of Speed
After a very successful rookie outing at the 2014 WOS, thoughts now turn to preparing for next year.
There will be some modifications to reduce drag. These may include modifying the ballast box because it sticks down below the crankcase, removing the instrument box and mounting the PV and AEM gauge directly to the upper triple tree, and sectioning the gas tank so I can get into a lower riding position.
Other possibilities include having the cases bored to accept larger cylinders so I can get to the 1350 class size limit, different exhaust cams and exhaust valves and gearing changes.
All that is needed is 11 mph to get the record!
Turbo Mafia Charter Member
Current LSR Record Holder: A-PBG 1650 134.594
RIP Sky Sanders
TGB #8
"Only those who will risk going too far can possibly find out how far one can go." - T. S. Eliot
Support Your Local Land Speed Racer -
The Last Truly Amateur American Racing!
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
Hell yea Tom, Ill be following your progress and helping where I can.
rocketmangb's Avatar
So you build an 82 incher without a stroker ?
3.687 Bore ?
Gets 1334 CC ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
3.700 bore. There's a ring pack available.
Click Here to Contact Me
Thanks Aaron
Im thinking normal numbers !
Sporty626 Sporty626 is offline
Other Motorcycle Year: 1987
Sporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura about
There is also the S&S 3 5/8 bore kit, 3.625 inch bore. You would leave some displacement on the table, but it's off the shelf parts.
But Why ?
3.625 Turbo piston is probably a custom piece anyway
Old 15th September 2014
I don't know how custom he wants to build it, just putting options out there. It would be one less custom part needed, apart from the pistons.
Nytstr's Avatar
Definitely going with the same custom turbo piston design that I'm running now, so Aaron is on top of it. Biggest deal is having the cases bored. I do need to pull the motor apart and see how the crank is doing, as it may need a teardown anyway. Ten runs at Bonnie could be tough on it, but really full boost was only happening on 2 runs.
Old 16th September 2014
Nytstr's Avatar
Actually I'm more concerned with what will happen in 2015. Now that I've figured out how to ride it I'll expect to be putting in hard pulls every time, so the abuse will be multiplied next outing.
