0 fp3
Last Post: 11alan111
0 Coronavirus & DK Custom Products - Update 3/18/20
Last Post: jazzman
0 15 sporty braided rear brake line
0 Resto-Repair 84 ironhead
0 Mid West Meet & Greet
Last Post: SLW210
0 Digital odometer
0 Dual Disc Conversion - Slider Clearance
Last Post: shrimp
0 No spark
0 xied or x14ied?
0 My 900: half-H, half-CH
Last Post: 83ironman
0 Shaking front end
Last Post: koolbreeze
0 Speedometer hookup - 76 XLH
Last Post: Mission1
0 Smaller turn signals
Last Post: lehel
Last Post: lehel
Old 31st May 2016
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Default Rocker Arm Oil Lines
http://www.ebay.com/itm/Braided-Stai...dTUu7q&vxp=mtr
Does anyone have any idea on the length of these?
You can't keep a good man down......... unless you tie weights to his ankles.
Old 31st May 2016
GA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant future
Don't know the length but found info in the Mid-USA catalog that says it wont fit mag Sportys, if that matters.
Hazmat Life
Old 31st May 2016
bobber58 bobber58 is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of light
They will fit mag Sporties, if you have enough clearance between them and the grounding lug on the side of the mag.
Old 31st May 2016
To be honest, I just need 1/8" NPT swivel lines for a breather bolt project on a Big Sucker 1. If these weren't too long/short, I'd stick them in a tee and add a catch can and be done, not have to make my own lines. Thanks though.
Old 31st May 2016
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
If these are for your 96 Evo?
You may get better responses in the Evo section, or at least some info on anyone that has tried your mod.
Ordinarily he is insane, but he has his lucid moments when he is only stupid
Old 1st June 2016
I was going to ask there but since it is an iron head part and all I needed was a length, I didn't think it would be an issue. I'm trying to repurpose a $10 part to make something somebody charges $50 for.
Old 1st June 2016
it's the ''if'' part.have you done this? the braided lines appear to be,thicker? the grounding lug protrudes approx. 1/2''.
Old 1st June 2016
for what matters, go to your local plumbing shop and get a braided line for lavatory, they will handle the heat and since you are venting should be no issues. the plus is if it doesn't mock up, exchange it for diff size.
Old 1st June 2016
Because they're billed as fitting an IH, I'll assume they're roughly the correct length. Mine measures roughly 9" from case to rocker box. Add a bit to that for the threaded portion of the fittings, maybe 1/2" per line, and through in a fudge factor for my in-the-dark, bending-over-the bike, measuring with a too-wide-tape-measure measurement. Carry the naughts and I come up with probably 9-1/2" ± from tip to tip. Maybe.
The reason they say not for magneto bikes: There's no way those would work properly on my bike, at least not be installed and look right, because of the mag geometry. Once installed, the mag would be perpetually grounded unless you set the body outboard by a tooth. And that's just whacked...
Old 1st June 2016
Thank you, that's exactly what I needed to know. I just want to drill and tap the backing plate , bring them down below the carb and run them into a tee, so anywhere between 8" and 12" will work, I was hoping these weren't too short.
