Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200
XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 For XR Sportsters: XR750, XR1000, XR1200
0 Battery melt down
0 Common ironhead problems
Last Post: SLW210
0 1960 XLCH in the UK
0 back to factory clutch
Last Post: Mark Jags
0 15 min rides
Last Post: drandall1489
Last Post: thefrenchowl
0 HELP! Extra part found
Last Post: syrnetworkin
0 Hello from Tampa, Fl
0 Replacement Clutch/Rotor Magnets
0 Resto-Repair 84 ironhead
Last Post: Yochstein
0 Getting Hammered
Last Post: Bryan1976
0 Greetings from Denmark
0 Howdy ya'll
Last Post: joes95bobber
0 removing clear coat on fork lowers
Last Post: flthd31
Last Post: chilly
0 88ci Sport Rod
0 Another from the Phoenix area
0 48 O2 sensor?
0 Phoenix AZ
Old 20th March 2018
Ftrack51 Ftrack51 is offline
Sportster/Buell Model: XR750
Ftrack51 is an unknown quantity at this point
Default Iron XR750 advice
Just joined the XL Forum as I am looking for advice on building an iron XR motor ideally in the late '71 factory team configuration with two rear mounted carbs and front exhausts.
Q.1: which H-D workshop manual best reflects the internals of this motor, '59-69 K KH XL XLH XLCH or '70-78 XL XLH XLCH, or are any differences minimal/irrelevant?
Q.2: is there any source of NOS or useable flywheels and con-rod sets? Will rods from an alloy XR do the job?
Q.3: I have been told to look for -57 heads with small ports but there appears to be a choice of casting numbers 16681, 16682, 16683 and 16684. Which are best?
Old 30th March 2018
barefoot barefoot is offline
Senior Bike Builder
Sportster/Buell Model: XR 750
Sportster/Buell Year: 1972
Sportster/Buell Model #2: RR 250
Sportster/Buell Year #2: 1976
barefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond repute
None of those. The iron XR is closer to the XLR than any of those. Even then the crank is different.
Flywheels no. Conrads are the same as the current XR. Or similar enough to use, anyhow. In iron XR days they had pressed-in races. New ones are carburized one-piece, otherwise the same. There's also 1" longer ones of the same design that you could use but those would be old. The crankpin is different and many of the bearings are different.
It doesn't matter. If you plan to duplicate any of the factory bikes you'll be getting real friendly with brass rod and a torch. They were brazed up by hand.
Lots of work involved for second-rate stuff. Easiest way to get where you want to go is probably scrounge a current XR and fit iron heads and barrels. The iron XR stuff broke. A lot. The crank is particularly bad.
Old 1st April 2018
Many thanks for the information; that certainly helps to map out the project.
Old 2nd April 2018
Senior Bike Builder
Ja, building an iron xr as it was done in 1970 would be replicating all the things that broke, not making something nice. You can't tell from the outside that an alloy xr is not an iron one (except for the heads and barrels) but they fixed a bunch of stuff internally. The whole crank arrangement is different. Just use late-model stuff.
Late-model in this case means 1972
It would be like reproducing an early 6V92, when they broke a lot. The later good ones look exactly the same but work great, so why copy stuff that's bad ?
Old 2nd April 2018
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Welcome to the XLForum.
Old 2nd April 2018
Thanks again Barefoot, I will aim to set up the iron motor like my alloy XR, or alternatively look for a turbo-diesel truck engine ;-)
Old 4th April 2018
Senior Bike Builder
... alternatively look for a turbo-diesel truck engine ;-)
If yer lookin for the race version, maybe an 8V53. Mmm, do they sound nice
