0 Getting Hammered
Last Post: scooby
Last Post: Jonv
0 Cracked motor mount
0 Sonnax, Timken, Torrington
0 Hack or trike?
Last Post: Firehawk
0 Indian FTR Sales
Last Post: xlerate
0 jiffy stand question
Last Post: Len PA
Last Post: brixtonanima
0 Spain near Barcelona -anyone know a welder?
Last Post: twohawks
0 Another Sporty ADV Build
0 What got you into bikes?
Last Post: spamer80
Last Post: vagrant318
jurneyman (78), AdO650 (64), xlsport (62), darth (59), mcsmokinp (55), stalkie (55), unleashed66 (54), 66xlch (54), lownslow (48), hrg (46), Ironduke (44)
  #141
Old 14 Hours Ago
ferretface's Avatar
Sportster/Buell Year: 1983
ferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to all
Page 3, post 24
I had read that and saw the .015" clearance but it was not clear if that was the side clearance or the radial clearance of the blade. I'm still not sure.
I'm up to page 10 of Dr Dick's thread. All Girls Garage on in a couple minutes. Gotta love those girls.
Old 13 Hours Ago
doodah man's Avatar
That post was illustrating radial clearance between fork radius and the radius where the fork rides in the gear. The thickness of the fork can introduce a small level of “slop” into the shift, but it’s not really enough to hurt anything unless the face of the fork that rides in the gear slot are severely worn too. Then you are looking at dogs being forced apart and/or missed shifts, and excessive forces applied to the finger rollers, etc... from not enough gear travel from too loose clearances.
Old 11 Hours Ago
ferretface's Avatar
I was still curious so I measured the side clearance between the fork blade and the slider gear groove. It was .008" for the m/s gear and .009" for the c/s gear.
I checked the sides of the fork blades and compared them with Dr Dick's pic. My blades do not have the wear triangle at the tip of the side of the blade, and the sides of the blade crescent show very little wear - I can't feel it with my fingernail.
So I'm going to go with these forks.
In bad news, my Eastern top hats measure .289" ID, .369" OD, and can be filed fairly easily. So I'm looking for NOS H-D top hats.
Old 8 Hours Ago
there might/should be info in that thread about using big twin top hats.
Old 7 Hours Ago
ferretface's Avatar
I did see that but I don't have a good grinder.
But I will see if anyone on eBay has NOS H-D 34168-39 top hats...
Originally Posted by Iron Mike View Post
I finally finished that thread. Good stuff. Sad link to Dr Dick's second last post. I read that post/thread also. Seems like there's an asshat in every forum.
