Keep & Kill
2 Days Ago
Posts: 463 Sportster/Buell Model: XLH 883 Sportster/Buell Year: 1995 Other Motorcycle Model: Honda CM450 Other Motorcycle Year: 1982
oil drain hose leak
Sometimes there is a small puddle under my bike, sometimes not. I think it is leaking at the drain hose, and traveling down it to it's lowest point. My bike has the hose terminating on a stud. I have tried tightening the gear clamp, but the rubber is 27 years old, so I just want to replace it.
I'm a little confused looking at the FSM, but I think it is telling me HD doesn't sell the particular hose for the bike, just 25' lengths of hose.
I'm wondering two things, new short pieces of hose don't usually like to be bent, does it matter in this case since it's only a drain hose?
And what size is it? 3/8 x 5/8 is what I THINK it is. Should just be able to head over to NAPA or Autozone and buy a piece, correct?
1995 XLH 883 Sportster Hugger
2 Days Ago
Posts: 8,606 Sportster/Buell Model: Xl1250S Sportster/Buell Year: 98 Other Motorcycle Model: Kawasaki Vulcan 500 Other Motorcycle Year: 95
If you cut it the right length, you can bend it without kinking it.
I use auto fuel hose from the local car parts store.
The tee at the bottom is 1/2" up, 1/2" to drain plug stud, 3/8" to oil pump.
Kinking that hose may show up a a leak later, so try to not.
http://www.sportsterpedia.com/doku.p...ng_lubrication
2 Days Ago
Thanks. I did look for it on SP first, I don't know why I never can find stuff there.
2 Days Ago
You can use the search box also on the upper left side of each page.
2 Days Ago
I always use the search function, but I guess I don't ask the right questions.
1 Day Ago
Posts: 16,371 Sportster/Buell Model: XL1460C Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL1200R Sportster/Buell Year #2: 2006 Other Motorcycle Model: XL1200R Other Motorcycle Year: 2004
Randall, it’s the heavy ozone contamination in the southern Florida air, you’re doomed!
