Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle General Discussion and Problems
Last Post: splineman
0 Sportster Builds
0 Ironhead engine problem?
Last Post: Congojack
Last Post: JimVonBaden
Last Post: CrustyTubs
0 Tachometer Suggestions
Last Post: BigMek
0 The Strociek Project
Last Post: CT XR rider
0 72 ih stroker advise needed
Last Post: rocketnorton
Last Post: ZTatZAU
0 1968 ex barn dweller thread
0 Starter gaskets 74 XLH1000
0 Starting?
Last Post: Briank
Sportster/Buell Model: XLH883
Default rear tire
How much of a no-no is it to run the rear tire backwards? I noticed they mounted my new rear tire with the arrow pointing in the wrong direction!
Folkie Folkie is offline
I would think it's not a good idea at all.
Which model of Buell is this?
rocketnorton's Avatar
Sportster/Buell Year: 1970
Other Motorcycle Year: 80+
rocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud of
ive run a front backward
had directional tread
wore it out
didnt see lotta rain, but was run hard as it can be on fxr w/2 4p calipers
that said, i think id remount a rear on anything having real power
+ "they" f'd up and should fix it
free
pete
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
For modern tires it's a no-no for sure.
Tread pattern is only one thing.
The tire design of the belts on a rear tire is to deal with forces when accelerating.
On the front it's the opposite for braking.
I change a lot of tires in my shop and I check the direction a few times before I put air in it.
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1988 BMW K75
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
The tire is designed for strength and durability to rotate in the direction of the arrow. Also the tread pattern is designed to disperse water, dirt and dust in the direction of the arrow.
