Last Post: fafcpa
Last Post: 4schizzle
0 Boardtracker Project
0 Any experience with REBUILT title?
0 Smoke and top end job
0 v twin Crankshaft Bushing Plate Pilot and Reamer
Last Post: thecarfarmer
Last Post: psycho69
0 Clearance between clutch faces 1974 transmission
Last Post: Jaime1840
Last Post: rider61
0 Should I apolgise to Harley Davidson ?
0 Secret Australian Business
0 Sundowner seat positioning
Last Post: Sportyman13
0 gerotor pump details
0 Zippers 1250 kit
0 Battery
0 Gas tank rust!
Last Post: Piemonte
0 new from socal
0 Craiglist finds
0 Mid West Meet & Greet
0 ISO parts for my 1986 build
Last Post: Peteroo
Last Post: Peteroo
0 Colorado Trike
Last Post: stikflote
Old 30th November 2020
just recently i had gas running full stream from my petcock on to my hot front pipe and it didn't ignite.apparently you need a spark for that.i was surprised it didn't light.
Old 1st December 2020
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
I "have heard" that it is not so much the liquid gas but the gasoline fumes that ignite easily. This, "they say", is why it is "safe" to toss a lit cigarette but into a can of gasoline.
Do not try this at home. At least, not at your own home
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
BitterOldMan BitterOldMan is offline
Sportster/Buell Model: Xlh 1000
Sportster/Buell Year: 1979
Other Motorcycle Model: Heritage Softail
BitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of lightBitterOldMan is a glorious beacon of light
As a former manager of a lab that did flammability testing on gases and liquids, I can tell you what you heard was absolutely true. A puddle of gas is much harder to ignite than vapors, due to the local oxygen levels in each scenario. Anyway, my leak was little more than causing some minor paint bubbles at the weld. My original question was with the brand I was dealing with. Didnt want to weld the leak up because I didnt want to repaint the tank. I, also, dont really want large chunks of delaminated epoxy floating around in my tank.
mikethebike61's Avatar
Solids do not burn
Liquids do not burn
ONLY gasses burn
The FLASH point is when the liquid or solid releases enough VAPOR that should an ignition source be introduced the vapor will ignitie
Contrary to popular belief the FLASH point and IGNITION point are not the same.
firewood is pretty solid.and is surely burns?
Old 2nd December 2020
Not until it off gasses
High school physics.....
only a gas will burn
you cannot compress a liquid
you only smell particulate.....
remember this next time your buddy cuts a bad one
Len PA Len PA is offline
Sportster/Buell Year: 1971
Len PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud of
Default tank sealer
Originally Posted by wolfryder View Post
caswell is what i have used and it works great
+1 caswell was used in this 1916 restoration
