0 primary cover
Last Post: smoggy
5 Eye Protection When Riding?
0 Inherited Ironhead
Last Post: bordens
8 Inexplicable miss
0 normal shifter shaft wobble
0 New guy from IL
0 Coil readings
0 Front Brake Upgrade
0 1992 XL ignition explained
0 3/4” Axle Drum Brake ??
Last Post: LLTattoo
0 Ignition advice
0 Chinese S&S carbs
0 Bandanas
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
0 Info needed on mini sumps.
Last Post: Randy_rots
Last Post: Akdawg
0 Noise and rod play
clutch, lug, shift, slap, sportster
Old 23rd July 2017
Manda's Avatar
Manda Manda is offline
Sportster/Buell Model: XL Hugger
Manda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to beholdManda is a splendid one to behold
Default Lug when starting off in first gear
I've noticed that sometimes my bike lugs in first gear. It happens right after I fully release the clutch lever, while the bike is accelerating. Sometimes I even hear a strange sound when it lugs, like something slaps inside the transmission. This lug is different each time. Sometimes I feel it very slightly, sometimes it shakes me like I've got hit in the rear tire from behind. It seems it depends on how aggressively I twist the throttle.
Also sometimes, but very rarely, when I shift from 3th to 2th, it makes a terrible sound which lasts for about 1/2 of second, then it slaps and continue running. Sounds terrifying, like when you touch a spinning propeller with a screwdriver.
I've did a detail inspection of primary chain tension and adjusted the clutch all by the book. Primary oil replaced a week ago. I'm running out of ideas...
Old 23rd July 2017
ChefRex's Avatar
ChefRex ChefRex is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XB12X
Sportster/Buell Year #2: 06
Other Motorcycle Model: XLCH
Other Motorcycle Year: 65
ChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to behold
Look for dust around the front pulley, could be the splines stripping.
Old 23rd July 2017
That slapping might also be excess play in the primary chain?
Old 23rd July 2017
Manda's Avatar
Chain vertical free play is about 10-11 mm, measured when cold.
Old 31st July 2017
VaFish VaFish is offline
Sportster/Buell Model #2: 883 Blue
Sportster/Buell Year #2: 1997
Other Motorcycle Model: A pile of Ninja 250's
Other Motorcycle Year: 1988
VaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond repute
Sounds almost like the problem I'm noticing on my sons 2001.
http://xlforum.net/forums/s...=1#post5572291
