Last Post: Scott
0 My 1250 to 1275 build
2 Humble pie
Last Post: Sprtstr1200s
0 WTF Happened
0 super b overflow
0 HSR42 on a 90" ?
Last Post: t120r
0 Ironhead questions
Last Post: Chicken-hawk
0 Operation Live Wire
Last Post: WI_duker
Last Post: Bryan83taco
0 2020 Sportsters
0 Just bought my 48 and love it! However... (Expected Much More Power)
0 Flame's New 1989
0 Mikuni HS40 flatslide
0 Hello
0 04 Rear engine mount pivot shaft spins when trying to undo drive side swingarm bolt
0 Yet another issue with this build
Last Post: Bruce
0 Touring on A Sportster
0 Roseville CA?
Last Post: Bryan1976
0 Ftr 1200
Last Post: Jason's Sporty
0 Valve to piston contact
Old 3 Days Ago
93trident's Avatar
93trident 93trident is offline
Sportster/Buell Model: 883c
Other Motorcycle Model: Triumph
Other Motorcycle Year: 1993
93trident is an unknown quantity at this point
Default Brake upgrade
Hi thanks all again for all your help so far. What front brake upgrades do you use on your bikes. is there any compatible brake calipers of other makes/ models of bike that fit a 2004 883c . thanks
FFR
Old 3 Days Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
Recently done mine, see thread...
http://xlforum.net/forums/showthread.php?t=2072585
Old 3 Days Ago
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
I took a rubbermount 1/2" master cylinder and put it on my 2002 (with the 4-pot fixed caliper). Perfect ratio.
Old 3 Days Ago
mesalkn mesalkn is offline
Sportster/Buell Model: XL 883 Low
Sportster/Buell Year: 07
mesalkn is an unknown quantity at this point
https://www.arlenness.com/prodcat/02-966.asp
Check this kit out, i am tempted to do this for my sporty.
Old 3 Days Ago
ReddTigger's Avatar
that's just an oversized rotor and adapter, you're still using the same caliper and pads,
I'd recommend doing the Brembro brake upgrade. it's the simplest most effective way to ensure quality two finger braking.
inspiration came from this thread.
http://xlforum.net/forums/showthread.php?t=274658
States I've Ridden in
71.3 hp 70.8 tq
Old 2 Days Ago
93trident's Avatar
Thanks all. i now have a plan thanks to Harley506d. That will do me fine
