0 Bad Primary Oil Leak
Last Post: Jj145
0 dual carb heads on ebay
Last Post: Nitro57xl
0 Metal chunks in oil
Last Post: Cleavon
Last Post: Larry May
0 ***DK Custom - Limited Time MASSIVE Savings on Select Items - Up To 40% OFF!***
0 Air Cleaner Porn!!!
Last Post: bimbo
0 Spokes or Mags
Last Post: 51 New West
0 question about XLCH manuals
Last Post: xena
0 Best seat for long rides
Last Post: Knuckles
0 Chain kit
Last Post: tonystylec
0 Shoei GT-Air II FF Helmet Review
Last Post: MotoMoshe
0 ,09 Iron883N idling weird, sputters on accelerating from idle or low revs.
Last Post: CarlOzzy
0 New from Washington
Last Post: owlsplace
Last Post: Renecito
0 Your Favorite Style
Last Post: Hornsmith
Last Post: xElvis
0 Cleaning Fuel Injectors
70 ironhead piston basket
  #51
Old 3 Days Ago
Momentary Specialist
Sportster/Buell Year: 96
Other Motorcycle Year: 99
Despite the "advice" I would not get rid of the stroker, properly assembled it will provide significantly more smiles than a stocker. It is no more difficult or expensive[1] to put together than a stocker and the difference in torque is amazing!
[1] Pistons will likely be a bit more expensive as they are not an off the shelf stock item.
I’d agree.
If the engine ends up coming apart, just put it back together with better workmanship. I.e. I’d want another set of rods, this time clearancing them carefully and having a smooth blended finish.
It looks like the pistons are stock. The skirts were shortened to clear the flywheel and the spacers to allow stock compression height pistons. If that is true and you measure the spacers and extra gaskets, it should equal half of the increased stroke.
That could be done again with stock pistons, just a better job.
If anyone ever needs piston modifications of any kind, I.e. lightening, skirt modifications, dome or dish work,etc... Rebco Machine is the best in the business. Good turnaround and reasonable too
(Eric)
Rebco Machine, Inc
1100 West 37th Street North
Wichita, KS 67204
Phone: (316) 440-2828
Sleepy Labeef rides again!
Old 2 Days Ago
Sportster/Buell Year: 1969
Other Motorcycle Model: 04 Ironhorse Outlaw
RicThompson is an unknown quantity at this point
If you pull it apart and find you have 4.5 inch stroke Truett and Osborne flywheels please let me know how much you want for them. That is if you decide to return your engine back to stock. Which cams does your engine have? They may have to be replaced also when you go back stock.
Old 2 Days Ago
I got to looking at the rods and I think the bad thing has happened.
The forked rod looks like the big end got hot.
