Last Post: fafcpa
Last Post: davesz1r
0 Brotherhood of the traveling lid
Last Post: FiftySixer
0 WANTED, Mid Controls for 2002, 883 Sportster
Last Post: tylermiller
Last Post: Edster
Last Post: commando57
0 Tappet blocks and tappets
0 XR mutt race bike progress
0 Coil readings
0 New guy from IL
Last Post: Bow only
0 Top end failure
Last Post: Tipofthelake
0 Valve Lengths?
0 3/4” Axle Drum Brake ??
0 primary cover
0 Why such heavy oil in Sportster?
0 Andrews 5th Gear Mainshaft Swap
Last Post: Diemos
0 Key
Last Post: Mike1nw
0 Chinese S&S carbs
0 Why No Tachometer?
Last Post: Mike1nw
0 Mods/upgrades
Last Post: Mike1nw
0 Info needed on mini sumps.
Last Post: Mike1nw
0 Ignition advice
Last Post: Rhode Warrior
0 "S" model specific Q&A
0 Clutch springs
Last Post: jsandidge
Last Post: jcro61
daggar rider, The Brit (67), MGN54 (66), beau-kat, bkmthdff (55), af_sting (51), ofo (49), LOSTHIGHWAY420 (46), coxja (40), rickeybyrd (35)
Old 25th May 2020
bmax13 bmax13 is offline
Sportster/Buell Model: XL883 Roadster
bmax13 is an unknown quantity at this point
So after some digging, found out the c clip for my detent plate fell off. The plate itself was all gnarled up, glad I took a look at everything before it got really bad! Just ordered the new plate as well as some other parts, should be back on the road in a week and half or so!
2002 XL883 Roadster
Old 25th May 2020
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Glad you found it.
Old 25th May 2020
Good for you and thank you for keeping us in the loop.
Old 25th May 2020
Highly-Dangerous's Avatar
SPANIARD
Good!!! and thanks for posting the outcome.
Old 25th May 2020
Here's some info about the Shifter Detent Plate:
http://sportsterpedia.com/doku.php/t...e_the_trapdoor
While you have it down, you might want to look at your clutch - Check and/or replace the Spring Plate in the center of the Clutch Pack. Also Check/Replace the Release Bearing.
http://sportsterpedia.com/doku.php/t...vo:priclutch01
Maybe check the chain tensioner.
http://sportsterpedia.com/doku.php/t...vo:priclutch02
(Side Note: I was riding in Lancaster County just last week - see My Motorcycle Chronicles)
Old 27th May 2020
Small world! Lancaster County is a beautiful place as long as you can get past the cow manure Thanks for the added info! I’ll be sure to check up on a couple things before I button up the primary again. Parts won’t be in for a little while (didn’t know how long Ronnie’s Harley took to process and ship parts), so might as well since I have all this time on my hands.
Hey y’all so my parts JUST came in now, which really sucks and seems very uncharacteristic of Ronnie’s Harley.
But regardless, I have 2 questions:
1) i decided to go with an e clip and washer over the stock circlip. The only thing is, I have a washer that makes the plate be tight up against the shift drum pins without any wiggle, and one washer that allows for a little wiggle. Which is better? Does there need to be some “wiggle room”?
2) As I’m testing the shifting I can shift from 1-3 perfectly fine but it gets hung up at 4th gear on the detent plate lobe. If I follow the service manual to a T when reassembling everything, is this okay to have? Will I be okay with putting everything back together and it will shift fine when I get it running?
Post no Avatars!
Sorry for a late response. I would go with a little wiggle room.
Too tight and it will press on the e-clip and may 'push' it away too much.
When shifting a tranny when the bike is NOT running you need to rotate the gears so the dogs will line up.
