0 back to factory clutch
Last Post: Bored now
0 15 min rides
Last Post: CMCSSeabee
0 Range With EFI 3.3 Gal Tank
Last Post: corndog76
0 Branch Mikuni Air cleaner question
0 Resto-Repair 84 ironhead
Last Post: lynnx
0 1960 XLCH in the UK
Last Post: lynnx
Last Post: Guidorey
0 E85 Fuel
Last Post: hondo
Last Post: fafcpa
0 Replacement Clutch/Rotor Magnets
0 97 Sportster Kickstand Problem
Last Post: Dirt Road Cowboy
0 removing clear coat on fork lowers
0 HELP! Extra part found
Last Post: syrnetworkin
0 48 O2 sensor?
Last Post: jvandivere
0 Starting issues (No Spark)
Last Post: jimstogs
0 The forum got talent
0 Battery melt down
0 Common ironhead problems
0 Hello from Tampa, Fl
0 Getting Hammered
Last Post: Bryan1976
0 Greetings from Denmark
Old 8th September 2019
Air-Cooled Forever
Do they say "Harley Davidson" on them? If they do the part # at HD.com is 53061-00B and only fits '00-'17 Softail models
Old 9th September 2019
W3LD3R W3LD3R is offline
Sportster/Buell Model: 883 XL Custom
W3LD3R is an unknown quantity at this point
They say HD in a few places but there’s only a 6 digit number on each bag. So I don’t know if that’s a model number?
Joe_jeep's Avatar
Joe_jeep Joe_jeep is offline
Joe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant future
vegas mod them.
make your own brackets.
make them fit!
jmho
Old 10th September 2019
Would I be able to find brackets online? What about keys?
mikeLI_77's Avatar
mikeLI_77 mikeLI_77 is online now
I don't see anything on Ebay that looks like it is for those bags but you may be able to get away with a pair if eazy brackets but they will push the bags outwards more from the bike. Could also try a pair of cycle vision barebacks if the holes in the bags line up with the holes in your fender struts then you could use some angle iron to go down and under the bags for additional support possibly.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Ok thanks for the info. Any ideas on keys?
Glamazon Glamazon is offline
Sportster/Buell Year: 2014
Any locksmith should be able to make keys. Don't know where you are but I use Timpsons. I was a hotel worker and we changed the front door lock anually for security (and when guests lost keys)
xena's Avatar
xena xena is offline
Assistant Administrator
Sportster/Buell Model: 1212 conversion/497 cams
Originally Posted by Maxeffort View Post
The only way I found was from an image hosting site, then copy and paste the BB code link into your post.
You can create a picture album here on the forum
in the community/pictures section.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Ok thanks for the idea
Old 15th September 2019
mwXL 2006's Avatar
mwXL 2006 mwXL 2006 is offline
Sportster/Buell Model: xl 1200c custom
mwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to behold
Originally Posted by W3LD3R View Post
No unfortunately I didn’t get the mounts with them. That’s why I’m wondering if anyone has seen these before and has an idea of what the brackets look like. The rhinestones are meant to be there. They are around the locks. I’m also looking for any information on keys for them.
Locksmith for keys possibly.
Xl 1200c custom 2006 carb.
42 CVP pilot 180 main
3 out a/f screw
V&H straightshot slip-ons
K&N Hi-Flow 587 air cleaner
Breather Bolts to air
Love to ride. Stay safe
Milt
http://sportsterpedia.com/doku.php/start Use it great info
https://postimages.org/ for your photos
