Last Post: BigMek
0 Xl???
Last Post: BigMek
0 Need Tuning Advice 1275 Kit 560 Cams
Last Post: XL1275
Last Post: Nitro57xl
0 Generator light q
Last Post: BigMek
0 so it's officially ended
Last Post: fafcpa
Last Post: soundnav
0 is a buell a harley
0 Nup 1009 (Bearing)
0 The Sport(ster)ing Life
0 S&S Super E Carb
0 New to me 55kh
Last Post: 11B40
Last Post: Skeezix
0 Round Air Cleaner Poll
Last Post: Joe_jeep
Last Post: 77IRHD
0 Finnish custom rider
Last Post: FinnDRZ
0 AGM battery for 76' XLH
Last Post: JonesL
Last Post: 1200CustomHD
oil pump install, oil pump removal, oil pump upgrade
Old 23rd July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Default Oil Pump Upgrade with Pics
Thought I'd share this walk thru with pics for those thinking about about upgrading their oil pump to the 07 one with improved scavenging. Part number 26204-91A. There's a few helpful tips for anyone thats never done it. First, get a service manual if you don't already have one!
Then go out get yourself a long 3/16 ball end allen with a socket drive. Can't stress the importance of this in getting to the bolts. I bought this set at advanced auto for like $26. You can find them individually without the sockets attached too. Even with this it's tight getting to the 2 bolts necessary as you can see by the next pic and the powder coating rubbed away from the bit. Pay close attention to getting it on the bolt straight. It's a tight fit.
But first remove the cam cover according to instructions in the manual. Best to remove the front exhaust pipe and rear brake pedal assembly too for easy access. Cover the cams with cellophane. I do the same with the heads and drape a couple shop rags over them to keep dust and dirt out.
Remove all the oil lines from the pump using a 9/16 and 5/8 on the flare connection for the feed line going to the filter. The others are clamps you cut/pry off. New clamps will come with the pump. Then remove the pump using the long 3/16" ball end allen on the 2 bolts. One closest to the front nearest you and one to the rear on the inside. The pump will drop down and wiggle out. It may be stuck on by the gasket and may bind slightly on the drive gear but it will come out. Remove the stuck gasket and clean the gasket surface of the case.
Take the new pump and work assembly lube into the opening as shown and rotate the shaft working it in to the gerators to help prime it with oil on start up. Put some on the gear as well. Clean any lube from the gasket/case mating surface. Install pump the same way you took out the old one. I found it best with the pump dropped down to put the bolts thru to keep the gasket in place. Then push it up and start the one closest to you by hand. Make surevvthe gear isnt binding with the drive gear. Hook the lines up checking their condition. As you can see I had one that was ready to start leaking that needed attention. I also wrapped some rescue tape in a couple areas prone to wear for added security.
Lube the cams and bushings in the cover. Then I have 4 longer bolts with the heads cut off I screw in the case first to hold the gasket in place and line the cover up. Slide it on, start a couple case bolts and remove the 4 temporary ones. Snug them all up and torque to specs and in the sequence shown in the manual. Make sure you connect the breather hose to the fitting inside of the cover you disconnected to free the cover BEFORE you put it on! The one that vents to the oil tank.
As you can see my cover has been modded with a crankcase breather in front as well. Thats a separate and different type vent covered in another section and it replaces the umbrella valves and head breather bolts.
Reinstall the rocker boxes, exhaust, and rear brake assembly according to instructions and specs in the service manual. DON'T FORGET TO PUT OIL IN BEFORE STARTUP!
See converting head breathers to cam chest breather in the Sportsterpedia for more on the cam chest breather.
Old 23rd July 2019
Highly-Dangerous's Avatar
Excellent! thank you for the write up.
NOTE: it might be my eyes are getting old but.... could you leave a blank space between each pic? it will make it easier on the eyes....
I am picky am I?? lol
Cheers.
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 23rd July 2019
60Gunner's Avatar
Cheers.
Done.
Old 23rd July 2019
60Gunner's Avatar
Oil is returning better. Filled it to 2/3 on the stick last night. Just took it for a ride and it's full. No bubbles or foaming at all. I mean none.
Old 23rd July 2019
Hippysmack's Avatar
Excellent write up and pics Gunner!
I like seeing greasy ass cams. Just the way they should be...maybe even more.
Glad everything's working out.
How's the krankvent working?
And how noisy is it, really?
Old 23rd July 2019
60Gunner's Avatar
Haha, I had to wipe a little lube off so I could time them after I pulled the cover back off because I forgot to hook up the vent hose to the tank. Front exhaust cam came with it. Stuck in the case bushing because of the lube most likely and wasn't too careful pulling it off.
The motor sounds deeper not really louder with the krankvent. I can feel it's not working as hard too. Noticeably on both counts.
Between the 2 I have no bubbles and my oil level went up after a ride today. So it's definitely returning better.
Old 23rd July 2019
Hippysmack's Avatar
I meant the krankvent itself. But if it's not reed valve, it probably wouldn't be louder.
Cool. I'm glad to hear everything's good.
Old 24th July 2019
60Gunner's Avatar
Nope valve isn't loud.
Yeah, just giving it a bath and putting a y8 needle jet in. Little lean in the transition but the 96 needle is a bit rich. This will be like using a 96.5 needle. Richer but without coming on earlier by raising it too.
Old 24th July 2019
Sportster/Buell Year: 1988
Glad you can confirm my observation. I had the same with my ET vent. With a properly working PCV, less air is trying to get out of the crankcases
via the scavenging, so less aeration. My valve is a bit noisier particularly on a cold start-up but it is a floating reed valve, so I suspect it will cope
better at higher revs than elastomer.
I am not sure if you have an oil baffle fitted; have you had a chance to assess how much oil gets past the Hayden valve yet?
Old 24th July 2019
60Gunner's Avatar
I do have a baffle and so far not a drip.
