0 New oil tank
Last Post: fafcpa
0 Big bore Stroker problem
6 brake caliper spacing
Last Post: swampig
0 Fyi
0 Bike wobble question
0 One More Ohio Meet & Eat?
0 Perfect riding music
Last Post: seajay
0 Gear Spacing Question
0 1969 Shifter shaft bushing
Last Post: sleighcrane
0 WTS: Forward Controls 2004-13
0 It's Glamazon's Birthday!
Last Post: XL1275
0 too much oil in primary
0 Oil leaking
Last Post: tizard
0 Rear cylinder exhaust nuts
Last Post: XL1275
0 Thread pitch for 91 front engine mount bolts.
0 stumble
0 Done for now (no really)
Last Post: Eric Von Zipper
5 Favourite grips?
0 What Carb
Last Post: salmanmr
Last Post: jcro61
Old 10th August 2019
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
HD says you need the "perfect fit" pushrods !
Yeah BS,check the preload,stock might work or ya some .050 short from Hammer
.050” shorter is probably in the range, but of course I will check the lifter preload. I can buy very high quality pushrods made in .050” length increments... or have Smith Brothers make any length, with any end.
