0 manifold leaks
Last Post: hbsporty
0 Bike sold leaving forum
Last Post: A Seabee
0 DK Custom Bullet Visor Style Halogen Headlight Relocation Kits
0 It’s Glamazon’s Birthday!
Last Post: BSA Bob
0 Hammer / Axtell cylinder weights?
Last Post: rubine
10 how low do you let it idle
Last Post: csmith72
0 Headlight Temps with 55/60W bulb?
0 Brand new Golan petcock issue
0 Digital speedometer
Last Post: csmith72
0 1960 XLCH in the UK
0 DK Custom Billet Tank Lifts - New Sizes & Finish - Q&A
0 crank case breather
0 Shocks on CL for Ironhead?
Last Post: Whitewalls
0 stress killer
0 570's or 536, 560's @10:1 Compression
Last Post: Turbo Sporty 48
Last Post: Joe_jeep
0 *DK Custom - M8 Softail Passenger Pegs - Now You Have Options - Intro Savings*
Old 5th September 2019
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
Default Suggestions on no start
Bije fired up last week w 2 to 3 kicks about 4 5 times in a day..since then tried to kick it n no luck..put in the blue streak points n condensor...still have spark on my plugs n spark at the points..any suggestions
Sent from my LM-X210APM using Tapatalk
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
gas getting to the carb?
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Did you reset timing after BS points install?
mickey t's Avatar
I checked to make sure gas is flowing through the line n it is as far as in the carb I wouldn't know where to start....I hear ya dint want to be digging in the vm38
mickey t's Avatar
Yeah used the straight line on the flywheel
doodah man's Avatar
There’s not much digging to be done in the vm38. Are you getting any signs of life from the engine at all - cough/wheeze/puff of smoke out of the carb - when you kick?
Whitewalls's Avatar
Sportster/Buell Year: 1971
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
If I'm understanding correctly the bike started in 2-3 kicks consistently last week. Since you installed the new points now it won't start. Common sense says something is not right with the points. Must have .018 gap on both lobes and make sure timing is set correctly. The VM38 is mostly fool proof as long as the supply is good. Keep it simple:
Timing, spark, compression and fuel = go!
mickey t's Avatar
Yeah that's a simple carb...no sign of life at all but it happened w the other points in it as well I had one good day w it consistent starting then 2 days after tried again n nothing..then put in New points n still nothing..used matchbook as my gauge since I hear its close to 18
mickey t's Avatar
Yeah it happened w the other points as we had one good day of kicking it over..so hoping the blue streak points would fix it but still nothing.
mickey t's Avatar
Yesterday I had a small pop but othsr than that nothing...
