Food porn
20th March 2023
Posts: 46 Sportster/Buell Model: xl1200c Sportster/Buell Year: 2003
They installed my front tire backwards. How much does it matter?
My local independent shop (two guys; the owner and one employee) installed my new front tire opposite the directional arrow. As much as it's a pain for all involved, I think I have to take it in and ask him to make it right. But I'm still curious: how much does it matter? The tire must be designed to sipe water in one specific direction, but I wonder if it matters with the tire's structure or contact material.
The thing is, it looks right intuitively (to me at least) but everywhere I've checked, including on the markings on the sidewall, it actually is backwards.
The tire is a Michelin Commander 21 90/90
20th March 2023
Posts: 1,185 Sportster/Buell Model: 883 Evo Sportster/Buell Year: 1989
The carcass is biased to resist braking action (since it sees no other).
The rear tire is biased to resist acceleration.
20th March 2023
Posts: 16,306 Sportster/Buell Model: XLCH stroker Sportster/Buell Year: 1960 Sportster/Buell Model #2: 883 C Sportster/Buell Year #2: '03
it's not correct.i would take it back.the directional arrow can't be argued,it's obvious.
72 1000cc barrels and XLR heads, S&S 4-1/2'' flywheels, sifton minus-minus cams, S&S super A w/ zippers thunderjet w/yost powertube, Andrews gears,and shafts, 72 oil pump, Morris magneto w/auto advance and single fire module, cycle electric generator w/electronic regulator,73 cu.in.
20th March 2023
Dazed & Confused
Posts: 3,616 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2017 Other Motorcycle Model: BMW R9T Other Motorcycle Year: 2015
+1
Go back and get it installed correctly. It matters because of how the tread rubber is lapped and how the tread pattern disperses water.
20th March 2023
Air-Cooled Forever
Posts: 3,424 Sportster/Buell Model: XL 1200 C Sportster/Buell Year: 2006 Sportster/Buell Model #2: (Prev.Own)XLH Milw.Spec. Sportster/Buell Year #2: 1981
Hydroplaning would be the biggest concern.
20th March 2023
Posts: 104 Sportster/Buell Model: 1978 ironhead sportster Sportster/Buell Year: 1978 Other Motorcycle Model: 81 fxe lowrider
Tire put on backwards
Bring it back and get it put on acording to the arrow on the tire it will matter in the long run
20th March 2023
Posts: 699 Sportster/Buell Model: XL1200T Sportster/Buell Year: 2017
In the UK when the vehicle goes for its annual test the wording is the tyre must be fitted in accordance to the instructions on the sidewall.
What I did when I took my wheels in for new tyres was put an arrow on the brake disc for clarity.
20th March 2023
Posts: 2,688 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2009 Sportster/Buell Model #2: XL1200L Sportster/Buell Year #2: 2009
I hope you don't need to ride in the rain a lot. But yes, get it put on the right direction. The Commanders are not good at braking on wet pavement. I was running a 110x19 & had to be very, VERY careful to not lock the front under any slow speed, wet conditions. The rear would slip under normal acceleration from a stop, also. I've put over 200,000 miles on 3 Sportsters in the last 20 years & the Michelin Commander IIs were the only tire I ever had that issue with. They cornered well, wet or dry, & lasted for about 12,000 miles, but I only used the one pair, when they were first newly available. Did not appreciate having to change my braking habits because of a tire choice. Nothing but Metzeler 880s & 888s for me, since then.
20th March 2023
Posts: 12,969 Sportster/Buell Model: 883 custom Sportster/Buell Year: 2004 Sportster/Buell Model #2: FXST Softail Standard Sportster/Buell Year #2: 2003 Other Motorcycle Model: FLSTF Fatboy Other Motorcycle Year: 1999
I've never had the experience of riding on a reverse mounted tire so I can't say. What I will say is there has to be a good reason for the tire companies to go to the trouble of printing the arrow. I would take it back.
22nd March 2023
Posts: 11,396 Sportster/Buell Model: 1200s Sportster/Buell Year: 2001 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1974
+1 on the hydro-planning issue. the pattern is supposed to point downward in a "V" shape.
as far as resistance to brake and acceleration, not so much.
do not think it is so much an issue with a mc but auto world makes a diff. direction tires run in reverse will get less miles. there are three types of patterns and each has +/-'s.
most race cars use directional for performance. a lot has to do with the environment in which the tire is run.
on mc tires, it makes a diff between running say a front on a rear position. been there done that because i was forced to do so. smoked that tire in 3k miles.
way back when, tires were universal more or less.
