Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sport-Glide / Sportster Motorcycle Touring
0 Piston size id?
0 Knocking noise in front cylinder!!!!
Last Post: Rossline
0 Forum problems???
5 Harley T-Shirts
0 Age limit where belts should be replaced?
6 Hello from Central Vermont
Last Post: JonW.
0 '06 Sporster Oil Tank drain
0 Fuel Pump Problems
0 Old Parts
Last Post: Hopalong48
3 Ironhead Pictures Thread
Last Post: Island Dude
0 1979 XLH Carb
0 Hello from Murcia-SPAIN
0 Gibt es hier keine Deutschen?
Last Post: Clementine
0 Hello from Germany
0 Operation Live Wire
Last Post: WI_duker
0 Need recommendations for 17"/18" Wheels (or maybe 19..)
Last Post: Edster
0 Trip to Rockies
Last Post: Blues
0 Magnetos
Last Post: Scott
0 Nothing much
Last Post: 83ironman
0 Oil Analysis?
0 electronic ignition
hubbinator (70), sport53 (66), kship (54), jrmkel (40), IR88n3 (35), waltweezy45 (32), lumberjack (29)
Old 15th February 2017
Low594's Avatar
Low594 Low594 is offline
Sportster/Buell Model: XLH1200Sport
Sportster/Buell Year #2: 1972
Other Motorcycle Model: Suzuki VStrom650
Other Motorcycle Year: 2008
Low594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to beholdLow594 is a splendid one to behold
Default Low594's XL12Sport
I just picked up a '99 XL1200Sport with only 5400 miles! I love to travel on motos, so this one is going to be built up to handle that.
Heres how the previous owner set it up
Here is how it sits currently!
Current Spec/Build Sheet
Comfort/Ergonomics
-Burly Footpegs(Previous Owner)
-ProGrip Rallye 714 grips(2/7/117)
-ProTaper 1-1/8" Contour Universal Low bars(2/7/17)
-Hardcase 7"tall 1-1/8" risers(2/7/17)
-Hardcase 7/8" Throttle Tube Kit(2/7/17)
-LePera Silhouette LT seat(2/19/17)
-HD Highway Pegs(7/9/17)
-CRG LaneSplitter 2.0 Barend Mirrors(7/9/17)
-ASV Adjustable Brake Lever(7/9/17)
-ASV Adj Clutch Lever/2015 Honda CBR500R Perch(8/9/17)
Engine Performance
-Hammer Performance 2.25" Crush Naked Filter Kit(Previous Owner)
-Vance&Hines SS2R 2into1 w/short can(custom by Previous Owner)
-MotoMechanix 3.8gallon Sporty tank(2/19/17)
-EMS HiFlow Fuel Petcock(2/19/17)
-HD Screaming Eagle 6800rpm ECM(7/1/17)
-HD Screaming Eagle coil, black(7/1/17)
-HD Screaming Eagle plug wires, red(7/1/17)
Electrical
-Joker Machine Front Turnsignals(Previous Owner)
-Speed Kings LoPro Smoked Taillight(Previous Owner)
-Cyclops Adv Sports H4LED 7000lumen bulb(2/4/17)
-3BR Powersports USB PowerPort(2/11/17)
-Dual 4" H4 housings, vertical mounting(7/15/17)
-Pangea Speed Headlight mount(7/15/17)
Luggage
-Small MOLLE Pouch(Previous Owner)
-Burly 20" Sissybar(2/9/17)
Protection
-EMS Black Ops Frame Sliders(fender strut mounted)(Previous Owner)
-Fire Brand Skidplate(2/8/17)
-Cycra ProBend Handguards(2/7/17)
-Alloy Art MX Folding Shiftpeg(2/19/17)
-Mooneyes Derby Cover
-TrackerDie Front Sprocket cover(6/10/17)
-ASV Rotator Clamps (brake master & clutch perches)(7/15/17)
Handling/Braking
-SuperBrace(2/23/17)
-Nissin 14mm 7/8" clamp Brake Master Cylinder (sourced from 2008 Suzuki VStrom650)(7/15/17)
-RaceTech Fork Springs(12/20/17)
-Racing Bros Bazooka HLR 14" shocks(12/30/17)
Style/Appearance
-Powdercoated HD 13 spoke wheels, fork legs, triple trees, Oil bag, Battery cover, etc(Previous Owner)
-Rough Crafts billet Gas Cap(Previous Owner)
-Kuryakyn Curved Laydown License Plate Mount(Previous Owner)
-DK Customs Front Tank Lift, 1.5"(2/19/17)
-Rear Tank Lift, 1/2"(2/19/17)
Misc
-Ram Mount X-Grip(2/11/17)
-Biltwell CV Carb Top(2/11/17)
-CV Performance Enricher Bracket(2/11/17)
-CV Performance Idle Screw(2/11/17)
Custom Work
-Coil relocated to upper motor mount
-Key Switch relocated to Battery Box
-Tiedown Spools on Fender Struts
-Machined left footpeg to reduce Derby Cover damage
Support your local creep! Creeps M/C
rwharris's Avatar
rwharris rwharris is offline
Sportster/Buell Year: 1990
rwharris is an unknown quantity at this point
Nice bike. How do you like that seat? Roger
Old 16th February 2017
Low594's Avatar
It looks and fits good, but after sitting on it for 10 mins I start wondering if there is any padding between the cover and the pan. Ive got the Saddleman Adventure on my VStrom, Im really thinking of hitting them up.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
Pretty nice ride if not for those HORRID risers.
What changes are you planning?
Low594's Avatar
Hardcase 9.5" risers, these have been removed and replaced by Hardcase 7" risers that run 1-1/8" ProTaper bars. Hardcase sells a 7/8" Throttle Tube kit to use dirtbike grips and Harley controls.
This shows how the previous owner modified the V&H SS2R exhaust
Factory Preload & Compression Adjusters!
Low594's Avatar
Agreed! Between the lower risers and the lower bars I put on, the grip height dropped about 5"!
Right now they sit a couple inches lower than my shoulders when sitting and I only have to lean slightly forward when standing.
Low594's Avatar
Upcoming plans:
-Better seat
-Saddle bags, something tidy like the LaRosas
-Highway pegs
-Better tires, aiming for Heidenau K60Scouts (I got 17,000 miles on my VStrom and they are very capable dirt and pavement tires)
-Larger tank (4-4.5gallons)
-Fork Brace
Low594's Avatar
Heres a few more up to date pics, Im really bad about taking pics when Im out riding. Ill try to get more soon!
Excuse the mess, Im moving in a month and the garage is my staging area
Old 18th February 2017
Low594's Avatar
I made a run upto the North Bay and got some parts, Screaming Eagle 6800rpm ECU with SE Coil and SE Plug Wires, a custom Sporty tank (3.8gallons!) and a LePera Silhouette seat!
Old 20th February 2017
Low594's Avatar
Couple pics with the new 3.8gallon tank. Im going to do a slight Frisco, for a couple reasons. 1) I like the look, 2) more tunnel space to run the wiring out of sight, 3) more air flow to the top of the heads and the coil & 4) now that the bars are at the right height, I think they still look too tall. Raising the tank will make the lines flow better
I also got the keyswitch relocated to a better location, the top motor mount.
I got the new Shift Arm and Alloy Art Shift Peg installed, still waiting for the factory Footpeg Mount to come in so I can replace the broken Burly MX Footpeg.
Word of caution on the Burly footpegs, the back inside corner needs to be ground down. If not, the sharp corner can punch a hole in the derby cover, then spilling oil. Mine didnt bunch a hole, but it was close and it did warp the Derby cover enough to cause a leaky seal.
