Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sport-Glide / Sportster Motorcycle Touring
5 Run/Turn/Brake light problems
0 Winter reading........
5 Terminology Sticky?
0 Sign of getting old...
0 gas tank paint protection
0 If you don't bring closure to your thread, then the terrorists have won
Last Post: Firehawk
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
Last Post: Jarlaxle
Last Post: oupa
0 Mainshaft- What happened here
Last Post: moparnut360
0 whats your iron head worth
Last Post: Whitewalls
6 Is Your SPORTSTER...
Last Post: oupa
Last Post: Kbetts
Last Post: oupa
0 Frontbrake upgrade - simple and cheap - how to will follow if there's any interest
Last Post: Yakcm2
0 How much should I offer for this 48
Last Post: oupa
5 my 3D printed turn signals.. what would you print?
Last Post: oupa
0 How to start a 1967 Sportster XLCH
Last Post: mjdart
pwssr, petefwa, skeeter883 (67), roadogette (66), khaskins (61), iriegnome (54), sportster808 (51), ironheadmax (49), matt275 (44), DJb (43), HDFirefighter (37)
Old 29th August 2018
Crusty Crusty is online now
Sportster/Buell Model #2: XL1200 R
Sportster/Buell Year #2: 2005
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1979
Originally Posted by Screw Loose Dan View Post
My nuts are multiple sizes...
That's probably why you've got a screw loose.
VaFish VaFish is offline
Sportster/Buell Model #2: 883 Blue
Sportster/Buell Year #2: 1997
Other Motorcycle Model: A pile of Ninja 250's
Other Motorcycle Year: 1988
VaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond repute
The best tools to have go unused on your own bike and get used on someone else's!!
Have you posted up details about what happened to your bike? What did you end up buying?
http://xlforum.net/forums/showthread.php?t=2070943
I thought loose screws and Harley's were synonymous.
SonWon SonWon is offline
Sportster/Buell Model: Superlow 1200T
Sportster/Buell Year: 2016
SonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond repute
Loctite, no problem.
Old 30th August 2018
Toejam503's Avatar
Subscribing Biker
Originally Posted by SonWon View Post
I didn't know that, my bike (36 mm) is a 2016. It is a big nut too, like the rider! Let the jokes begin.
Little hands, big nuts.
Dave L's Avatar
Dave L Dave L is offline
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant future
I am gonna throw together a small kit too. If you have one hopefully you wont need one!
Old 20th September 2018
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant future
I like large Crescent style wrenches but don't like the length in a tool bag. I got the idea to bob the handle from a bro in the 1980s. It makes them much handier even at home. I welded the cut off end of a box wrench to fit my spark plugs to the bobbed end, so I have a bobbed double-duty wrench. When doing an axle I break torque with my boot so the length isn't an issue.
On long trips I pack two small G.I. tool bags. It's an old Shovelhead owner habit but you can never have too many tools. A folding hex key set lives in each riding jacket and I always wear a Leatherman 300. I've worn out/broken three so far (abuse of course) and love the warranty.
A small BRIGHT flashlight is handy, but a rechargeable LED headlamp is even better because it leaves your hands free. They are useful at camp sites when nature calls. I wear them at home for task lighting when wrenching or working on computers.
I carry several feet of stainless aircraft safety wire. It can hold and retain many things.
Best way to figure what you need is look at your motorcycle while making a list of tools for typical jobs. You can boil it down to an optimal kit easily.
A multibit screw driver with a 1/4" hex bit size can be used on typical worm drive hose clamps without the bit to turn the nut. Speaking of which, stock Oetiker crimped clamps aren't reusable. I convert to worm drive or preferably, the "fuel injection" style hose clamps. Both work fine.
10mm "ignition" wrenches are small and handy for battery bolts.
I pop the circlips off my brake and clutch lever pivot pins, mainly because I hate the things when I need to replace a cable or lever. I've never lost one in more than three decades of riding. One less tool to f with on the road is a bonus. I first did that when my throwout bearing got eaten by a heavy clutch spring (on an FXR) and I didn't have clip pliers in my bag.
Graywolf Graywolf is offline
Graywolf
If you weld about a 4-inch long X 3/8" bar across the adjuster knob as a T-handle that gives you far more leverage over the visegrip than clamping by squeezing your hand. It's no contest, and more force means lower odds of slipping. If the bar is at a slight angle instead of a symmetrical "T" it's easier to spin the T-handle with your palm so don't worry about getting it straight.
I've done most of my standard visegrips and welding clamp versions and will do the rest as they wander near my welder. I also anti-seize the threads and run the screw fully in and out to coat them. Prevents weld spatter sticking and corrosion.
It is not for making them easier to use. The tabs are welded in there so they can be clamped on the shifter shaft when the threads strip out or the shaft gets rounded off so it won't hold no more. The old pot metal shifter arms were always breaking or stripping out. With the tabs on it you can use it either with the shift pedal in the tab or use it with linkage hooked to the tab. It will work on most any bike, not just Sportsters. They can also still be used as Visegrips for your tool kit.
