Last Post: sglock45
Last Post: hbsporty
0 clutch spring compressor
Last Post: mrmom9r
Last Post: fafcpa
0 my rear wheel
Last Post: stikflote
0 Trackiing/data mining tactics.
Last Post: Dan78
0 loose exhaust
0 Thunderstorm heads &1200 barrels
Last Post: spamer80
0 math problem, piston rings
Last Post: thefrenchowl
Last Post: RKN
0 Adding fuel level sensor to the speedo/tach
Last Post: Firehawk
0 Rubber mount parts that fit a rigid mount?
0 Tires!
Last Post: Yakcm2
0 How much is too much?
0 Correct Ultima Ignition
0 Valve stem seals
hillclimber (70), burtondl2 (52), Cet (50), hagar71 (49), ShaneWolfe (48), grizdiesel (43), Confused89 (35), RAIDER0372 (34), spamer80 (34), svwannabe
Old 15th November 2019
RDHenley's Avatar
RDHenley RDHenley is offline
Sportster/Buell Model: XL883C
Other Motorcycle Model: Street XG500
RDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant futureRDHenley has a brilliant future
You have spoke nipples that take an allen wrench? All the wheels I've done had spoke nipples that were threaded in that area (the rim strip end) and had a screwdriver slot. You can see that in the video you linked.
If they do take an allen wrench you certainly could count turns just like with a screwdriver.
I'd put up a picture but I haven't figured out how to get back into my photobucket account.
Old 20th November 2019
to each his own. the wrenches i got from them for the spokes were right on. the adjustable wrench will round off the flanks if you do not keep on top it it. the spoke wrench is wide to grab the majority of the nipple, thus less chance to bugger them up and when you buy some high $$$ units why take a chance, they were cheap.
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
When I was a school trained junior mechanic in an H-D shop in ‘74 I made 4.00/hr.
I took wheels home at night and sat with my woman listening to Hendrix and lacing and truing wheels on an old swingarm. Both HD and Bultaco.
I made $30 a wheel. No wheel ever took me more then 45 minutes once I got my “technique” going. It’s an art worth studying. Even today.
Just last month I re-rimmed my 7 yr. old great nephew’s BMX bike. He looks at me differently now. So do his pals.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
That's awesome. Too many people now days would just trash a kids bike and buy a new one if the wheels were messed up.
Old 21st November 2019
that square bore bull was an amazing machine on the dirt, swear if it had the right tires, would climb a vertical wall.
So, the Bultaco rims were by far the ones I replaced most often.
Putting a 16” rim on an XL hub with the proper offset was also a big money maker back then.
This stamped orange rim is only twisted. The other one like it was really bent up. The machined aluminum, double wall units were only $16 each on eBay from Hong Kong. Very nicely made.
I had to buy a 2mm x .045 die to lengthen the threads on the spokes but it all worked out great. He loves the bike and it’ll be ready for his little brother too.
Old 23rd November 2019
RDHenley's Avatar
The FSM the better half ordered on eBay came in the day I left the house, and the rim came in yesterday. She says both look to be in good condition, but I'm going to have to wait until my next home time before Christmas to see them myself.
I thought about taking the wheel apart before I left the house, but decided it would be better if I wait until all the pieces where there to do it.
RDHenley's Avatar
Well, that didn't turn out as planned. Got to looking in the new service manual the better half got me for Christmas, and it turns out the profile rim uses different spokes and nipples. So, the better half is scrounging eBay to see what she can turn up. If that doesn't turn up anything, I'll have to wait for more bike budget to get new spokes.
Get the FSM, there's so much info in there it's mind blowing.
