fork seal
21st March 2011
Posts: 61 Sportster/Buell Model: XL883 Sportster/Buell Year: 2000
Stator Rotor issue / question
Test for the electrical guru's. 87 Sporty with charging issues. When we tested the resistance of the stator, it was in spec, but the voltage output was about 1/3 what it should be. Pulled the clutch basket to swap the the stator and inspect the rotor and see this:
magnet removed
One magnet is broken, a second is chipped, the rest I can shift around with my bare fingers (I removed the broken one to demonstrate). I always thought the magnets were fixed, and if there's an issue, you replace the rotor. These magnets are not fixed. See the uneven gap. Some were touching and others not.
Questions:
1) can I get replacement magnets for the 2 damaged or do I need a clutch basket (read this would break the budget)
2) Can I clean and reuse the intact magnets
3) should the magnets be fixed? perhaps I should use some epoxy or JB weld to lock them in place
4) if the magnets come into contact with each other, will that affect voltage output? I understood the function of the charging system to be to create pulses of magnetic fields for the stator winding to pass through, if the magnets are in contact with each other, it would essentially reduce the pulses per rev. Not sure my description makes sense, but I'm curious if this is strictly a rotor issue and not stator at all. Any insight appreciated.
21st March 2011
Senior Master Bike Builder
Posts: 2,103 Sportster/Buell Model: 883-1380cc hot rod Sportster/Buell Year: 87 Sportster/Buell Model #2: wife's 883-1200 Sportster/Buell Year #2: 87
Magnets can be cleaned and JB welded back in.
The real problem though, is a sloppy trap door.
The best fix is a Zippers double bearing trap door.
21st March 2011
Posts: 930 Sportster/Buell Model: 1988 883/1250
Dan at NRHS has a lined clutch hub that will also help...my 88 was so bad about that even with a zippers trap door and the lined hub I ended up swapping it for a 99 motor
21st March 2011
Posts: 9 Sportster/Buell Model: XL Sportster/Buell Year: 1986
22nd March 2011
Thanks all. Good to know I don't have to fork out for more than a few magnets. Will look into the zippers kit.
22nd March 2011
Posts: 11,299 Sportster/Buell Model: 1200s Sportster/Buell Year: 2001 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1974
this is a common fault with hd alternators. you are fortunate that it did not wipe the entire system out. when the magnet broke, it now forms two magnets and will interfer with the final output. the magnets are spaced as well as the stator winding posts to give a sine wave output but with the magnets messed up, the wave form will be altered and can cancel out each other causing a drop in voltage and amperage. you will not be able to get magnets from hd but you can get a used cup. if you do try to repair the messed up cup, make sure they are evenly spaced and the correct positioning of the poles are correct they should alternate n-s-n-s and so on. if not correct, the wave forms will cancel each other out.
as a note, you can try K&J magnetics to see if they can match the magnet. probably would be better to send an old one to match and replace all of them. sometimes when magnets are thrashed, they will lose some of their strength.
22nd March 2011
Originally Posted by bustert
this is a common fault with hd alternators. .
I suspected as much. I was going to call HD to order magnets, so thanks for the heads up.
