0 08 883L headlight stopped working
Last Post: Ssawahl
0 WTB: (used) OEM turn signals from Iron, Nightster, or 48
Last Post: JWNathan
0 Old man walks back into a forum..
Last Post: skien
0 New from the cold north...
0 First XL - XLCH or XLS?
Last Post: Magneto Sportster
0 Broke Down and Ordered an Optima Ignition Kit
0 mikuni vm38/9 on a 2001 xlh
0 Jetting 42 mikuni
0 fork seal
Last Post: wrkdWS6
0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 83 Sportster basket case
Last Post: joe s
0 Clutch Slipping at higher RPM
0 charging
0 Helmets Please...
Last Post: gusm2
0 forward controls for an 81
0 Allegheny 2023
Last Post: wardie
0 72 xlch is overcharging... bosch mechanical reg
Last Post: rocketnorton
0 R.I.P. Tina Turner
Last Post: MDT
0 Axle-grease question
0 Disappointed with Eastern shift forks
Last Post: davixlrtt
0 Highway Pegs recommendation
Last Post: Yochstein
0 Passenger backrest for 07 883?
0 Registration question
0 "S" model specific Q&A
Last Post: Model H
jeffcahill (70), jeebus (55), cdepaola (53), RubenAlonzo (53), chida66 (48), schneck0341 (46)
compression, kick start, kicker slip, valves
Old 3rd June 2013
pdgoede pdgoede is offline
Sportster/Buell Year: 1957
Sportster/Buell Model #2: WLC
Sportster/Buell Year #2: 1945
Other Motorcycle Model: Electra Glide 1965
Other Motorcycle Year: 1965
pdgoede is an unknown quantity at this point
Default compression after rain and heat
got the folowing:
ironhead 1957 rebuild is running very well. Did about 2000 km.
When doing a rally in Italy, the motor stalled after steap uphill in in the rain.
Tried tro kick it on and wasn t feeling any compression. Put it in 1st gear, rocked it a bit and was able to kick it on again.
I have checked the gaslevel, since it has been a steap hill, 2 gallons left still.
Engine was running fine again.
After taking gas in the afternoon , it happened once again, rocked it in 1st, kicked it on and runned great.
any idea what could be the cause?
thanks,paul
Old 3rd June 2013
antsap antsap is offline
Sportster/Buell Model: 71' XLCH
Sportster/Buell Year: 1971
Other Motorcycle Model: 1956 FLH
antsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura about
Would love to see some pics :-)
I'm taking a real stab at this so definitely wait for more responses ...
Maybe a sticking valve or lifter?
Old 3rd June 2013
vonh vonh is offline
vonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to allvonh is a name known to all
You should never go from full compression to no compression unless something is broke or loose. Is the kickstarter tight??
Old 3rd June 2013
i've noticed with my bike after riding for a good distance (up hill or not) if the engine is really hot, it feels like there's little to no compression with my kicker (it pushes through the cycle very easily, unlike a cold start where i can stand on the kicker and hardly move it), but like yours, it starts back up and runs just fine. i'm guessing it's perfectly a normal trait of a hot engine. as for your stalling out, could be rain soaking your air filter?
Old 3rd June 2013
Duplicate thread should be deleted.
Check pushrod adjustment COLD (stone cold).
Old 3rd June 2013
Hopper Hopper is offline
Other Motorcycle Year: 1942
+1 on wot Rick said. Check pushrod adjustment with cold engine.
When you say you felt no compression, did the engine turn over but felt no compression, or did the kickstarter just move without the engine turning over at all? If it was not turning over at all, it is probably a kicker ratchet jamming problem, and rocking it in first gear frees the ratchet.
Old 3rd June 2013
thanks guys,
I indeed need to check the ratchet as well. However it was strange to me that the engine stalled at first. Maybe a frozen valve or so. It's in transport now and will update when it's at home again.
Old 3rd June 2013
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I'll jump on the stuck valve bandwagon.
Old 3rd June 2013
Old 3rd June 2013
fergerburger fergerburger is offline
Senior Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of light
Like other said, pushrod adjust or sticking valve. sometimes when they ream the guides they leave a high spot in the middle of the bore if they use an adjustable reamer (as not all shops have the correct reamers). the valve will stick...also check your heads for torque as you can lose comp through the head gasket...not all leaks are audible.
