Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Custom Finishing
0 mikuni vm38/9 on a 2001 xlh
Last Post: wiltybob
0 Denatured or isopropyl
0 Broke Down and Ordered an Ultima Ignition Kit
0 New from the cold north...
0 First XL - XLCH or XLS?
0 83 Sportster basket case
0 08 883L headlight stopped working
0 forward controls for an 81
0 WTB: (used) OEM turn signals from Iron, Nightster, or 48
Last Post: JWNathan
0 Old man walks back into a forum..
Last Post: skien
0 Jetting 42 mikuni
0 fork seal
Last Post: wrkdWS6
0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 Clutch Slipping at higher RPM
0 charging
0 Helmets Please...
Last Post: gusm2
0 Allegheny 2023
Last Post: wardie
0 72 xlch is overcharging... bosch mechanical reg
Last Post: rocketnorton
0 R.I.P. Tina Turner
Last Post: MDT
0 Axle-grease question
0 Disappointed with Eastern shift forks
Last Post: davixlrtt
0 Highway Pegs recommendation
Last Post: Yochstein
0 Passenger backrest for 07 883?
jeffcahill (70), jeebus (55), cdepaola (53), RubenAlonzo (53), chida66 (48), schneck0341 (46)
Old 3rd January 2014
islanddave islanddave is offline
Sportster/Buell Model: sportster 883
islanddave is an unknown quantity at this point
Default Painting a Buell Cyclone Gas Tank
Hello All,
It's been a little while since I've posted. The Buell has been running great so I haven't needed any advice. I would like to get the tank painted. Is there anything special that the painter needs to do or know about painting these plastic tanks?
Thanks Dave
Old 4th January 2014
xlron xlron is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: 1994 xl
xlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to all
Just painted mine with the silver base color and am working on rivets and seams. In prep, I did a lot of research and came to the conclusion that I needed to get every drop of gas out and even left a towel in the tank overnight to absorb all the moisture I could. I then used a propane torch to bring the chemical : injection mold release agent to the surface, then wiped it off with 100 percent alcohol. Then sanded the decals off with 300 grit, then sanded the whole thing with 600. What a job!!, After a while it seems like you're doing a car, 5 gallons!!! Needless to say, I skipped the bottom. Don't leave the torch in one place, keep it moving. ANd , oh yeah. It's very conducive to aircraft noseart decals because of the shape. Have fun.
