0 Old man walks back into a forum..
Last Post: skien
0 New from the cold north...
0 First XL - XLCH or XLS?
Last Post: Magneto Sportster
0 Broke Down and Ordered an Optima Ignition Kit
0 mikuni vm38/9 on a 2001 xlh
0 Jetting 42 mikuni
0 fork seal
Last Post: wrkdWS6
0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 83 Sportster basket case
Last Post: joe s
0 Clutch Slipping at higher RPM
0 charging
0 Helmets Please...
Last Post: gusm2
0 forward controls for an 81
0 Allegheny 2023
Last Post: wardie
0 72 xlch is overcharging... bosch mechanical reg
Last Post: rocketnorton
0 R.I.P. Tina Turner
Last Post: MDT
0 Axle-grease question
0 Disappointed with Eastern shift forks
Last Post: davixlrtt
0 Highway Pegs recommendation
Last Post: Yochstein
0 Passenger backrest for 07 883?
0 Registration question
0 "S" model specific Q&A
Last Post: Model H
0 More advice.... (2007 Roadster Seat On 2011 Superlow?)
Last Post: wiltybob
0 .551 Cams in an EFI 1200
jeffcahill (70), jeebus (55), cdepaola (53), RubenAlonzo (53), chida66 (48), schneck0341 (46)
rotor, sprocket, wheel
Old 23rd April 2015
Skreetch Skreetch is offline
Sportster/Buell Model: 1200 Custom, Bobber
Skreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really niceSkreetch is just really nice
Default Which side does rotor go on?!
Once again, I looked for a thread that already answered my problem, and didn't find what I needed. I apologize in advance if reading another thread on a XL forum disturbs you.
I am converting to chain drive on my '04 1200 custom. I needed new tires on both wheels, so I ordered some, then I ordered a chain conversion (not as a kit, but in pieces) and about this time realized how much I HATE the solid sportster rear wheel. So after a long search found a reasonably priced chrome spoke with the correct bearing size. I inspected my rotor and it looks great, so for now I'll keep it (although the stock spiral/wavy directional design looks dated, and not like a traditional hot rod build dated, like mid '90's ugly dated). So I'm looking at my new shiny wheel, and my new shiny sprocket and the kinda shiny rotor and it dawns on me, I have no idea what side of the wheel the rotor or sprocket should bolt to.
Both flanges are identical, there is no offset on the hub, the bolt holes look identical on each side of the hub, there is no direction arrow stamped in wheel rim or hub. It literally looks the same whichever side you look at, except the hole for the valve stem is on one side. A truly bolt-on part? Absurd!!
So my question is: does it matter which side I mount the parts?
I'm asking because I don't know. Please keep it professional, and don't try and prove how dumb I am, I do that fine enough on my own! Lol
Old 23rd April 2015
jabba the slut jabba the slut is offline
Sportster/Buell Model: 883 XL
jabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant future
On my 99 the pulley side has larger diameter bolts than the disc side. Not sure if that remains true for the '04 model.
Don't worry about posting questions. Some little guys get their jollies pointing out that a qn has been asked previously, but I've been here a little while now and still find the search function tedious, and it gives us all a chance to chat!
cheers,
Gid
Old 23rd April 2015
AnaChris AnaChris is offline
Sportster/Buell Model: 883xlc/1250
Other Motorcycle Model: FLHRCI
AnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant future
you're among friends ask as you wish.
the bolt hole sizes should a good indication. when it doubt. mock it up and try it out. if the brakes don't drag and the chain tracks well then go for it.
Old 23rd April 2015
ReddTigger's Avatar
Typically the valve stem goes in the brake side of a sportster. .
States I've Ridden in
71.3 hp 70.8 tq
Old 23rd April 2015
trainman trainman is offline
Here is a good link on chain conversion..
http://xlforum.net/forums/s....php?t=1445691
Old 23rd April 2015
moparnut72 moparnut72 is offline
Sportster/Buell Model: 883C - Sold
Other Motorcycle Model: Softail Slim S
moparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond reputemoparnut72 has a reputation beyond repute
I too have the solid wheel. I like the looks of the spoked wheel and am considering a change also. Is there a big difference in weight? Would be another reason to switch.
kk
Old 23rd April 2015
Sportster/Buell Year #2: 1972
kk
Laced wheels are a fair amount heavier. They make up for it in strength (and looks in my opinion).
Old 24th April 2015
Thanks guys, I did a mock up and I am convinced both sides are identical. I will mount it with valve stem on brake side since that is what my stock wheel set up is.
I am a member on a Jeep forum, and I guess I am scarred, those guys are jerks if they have to re-read a thread! Which made me leave for another one. But sold my Jeep before I posted anything. Should have known Sporty guys were different! LOL
Old 24th April 2015
My chrome spoke is a little heavier, but it is still pretty light (I was surprised)
I am going away from the solid strictly for looks. I kinda like the wagon wheels on the back of you don't have two wire spokes, but I am not a fan of that solid wheel.
Not sure if it was Harley or Davidson who decided to go with miss-matched wheels, but it really is tacky.
