Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Photos/Videos
0 New member softail rim laced to sportster hub
0 New Member and a question
0 question for our machinists
Last Post: spuggy
0 Cold weather pants:
Last Post: RDHenley
Last Post: Roane
Last Post: denguy
0 Electrical question
Last Post: RDHenley
7 Ironhead yes or no
Last Post: spuggy
0 Getting Hammered
Last Post: andy_t
2 Humble pie
Last Post: Sprtstr1200s
Last Post: RDHenley
Last Post: Blue Scoot
0 oil return for stroker
0 Bobtailing a sportster
Last Post: 45Brit
0 Codes again !!!!!
Last Post: 93trident
0 77 XLH Starting issues no needle bearing in primary?
Last Post: MadMike_1126
Last Post: a-sad-anorak
Last Post: RDHenley
5 Your worst car?
Last Post: Traxx
Old 2nd January 2015
that is a later model front rotor. Used from 1997 to 1999 I believe.
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
Dan is right; it's not the stock S2 piece. The later 9 pin rotors from the '00-02 Buells are better, but as cheap as you can find the EBC front rotors ($200) that's what I would do. Before you replace it, check to make sure all the floating points are clean and make sure your mounting bolts are not stripped. I have one stripped and one almost stripped, which ai will be addressing soon.
Love is the never-ending act of forgiveness - Peter Ustinov
