0 tapped adjust
Last Post: ericfreeman
Last Post: XL1275
0 Question for Jorgen, Aaron, ???
0 The salty debate thread.
0 Kicker shaft question
Last Post: Captain Johnny
0 1200S race bike miss at 3500-400
Last Post: Proteus
0 Fuel Pump Problems
Last Post: Lowe175
0 Kick starter resistance
0 Which cams ?
0 Cycle Electric 5000 initial charge time?
Last Post: USAFpj
0 truing spokes question about centering
Last Post: ThrottleBody
0 New Jagg oil cooler adapter for 2004+ Sportsters
Last Post: Randy_rots
0 Matrix brakes
Last Post: tonystylec
6 ironhead turn signals
Last Post: 19ironhead75
0 Mustang Seat FS
0 Static timing
Last Post: ftwflh
0 how to check cam postion sensor
Last Post: ftwflh
0 Hello New in the Forum
Last Post: Dosmie72
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
Old 27th May 2007
jessearias's Avatar
jessearias jessearias is offline
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 1984
jessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nice
ENGINE: 2002 1200S
LOWER END: Stock
CYLINDERS: Axtell Cast Iron 1250
PISTONS: 10.5-1 Forged w/ 15 degree domes (supplied with 1250 kit)
HEADS: Buell Thunderstorm w/ NHRS Stage I porting, Dual plugged, Guides cut down to accept .600 lift cams, HD springs and retainers
ROCKERS: Stock
PUSHRODS: NRHS fixed .040 shorter
LIFTERS: New stock replacements from Comp Cams
CAMS: SE .536
CARBURATION: Mikuni 42 mm w/ Yost power tube , 170 main, 25 pilot
AIR FILTER: NRHS Hurricane 2" w/ stock ham can cover
EXHAUST: Rich Products Thunderheader
IGNITION: Daytona Twin Tec Model 2005 w/ VOES hooked up Custom map, 32 degrees total timing, switches set SELECT 7, SLOPE 5 (note that these switches are disabled with the custom map)
COILS: Two Dyna DC1-1 mounted with a Rivera Engineering coil bracket
CLUTCH: Barnett extra plate kit w/ Barnett HD diaphram spring
TRANSMISSION: Stock
OTHER MODS RELATED TO ENGINE: Pingel High flow petcock, Balance Masters crank and clutch basket balancers, .030 Cosmetic head gaskets, .020 base gaskets, Denso IXU24 plugs
COMMENTS: None
[FONT="Arial"] Jesse :smoke [/FONT]
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
