Last Post: Skeezix
2 My 1275 Hammer Conversion..
0 su carb question
Last Post: fafcpa
Last Post: DitchTBHSMM
0 New to the Chopper Lyfe
Last Post: brixtonanima
0 Too HOT to ride?
Last Post: Billy1200
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
View Poll Results: What mileage have you got out of your primary?
Less than 10,000miles - had it replaced under warranty. 0 0%
25,000 miles - I cane the tits off my tuned motor. 1 12.50%
50,000 miles - and still going strong! 3 37.50%
75,000 miles - so what's the problem? 1 12.50%
100,000 miles - my chain's still hanging in there, but I'm knackered. 1 12.50%
I haven't replaced the primary chain since 1975. 0 0%
What's a primary chain? 2 25.00%
Voters: 8. You may not vote on this poll
Old 2nd June 2011
steelworker's Avatar
Other Motorcycle Year: 2016
Default Primary Chain Lifespan
I've just had my clutch, engine sprocket and primary chain off, and it set me to wondering how long the primary chain can be expected to last. All chains have tight spots, but how can you tell when it's truly knackered? When you run out of adjustment on the tensioner?
Old 2nd June 2011
rottenralph's Avatar
Mine is stretched to the point of replacement as soon as I replace my clutch. I have 40K and I drive like I stole it most of the time.
Old 2nd June 2011
I ride in a similar fashion, Ralph, and have over 50,000 miles on the original chain. There's still loads of adjustment left on the tensioner, but there is one point of the chain that's a fair bit tighter than the rest, and I'm starting to wonder...
Old 2nd June 2011
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Maybe it's time to change it then Myles.
Stuff: YES
Old 2nd June 2011
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I have about 45,000 on mine and I'm just about out of adjustment range.
Old 2nd June 2011
I'm thinking the same thing.
Old 2nd June 2011
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
I've never had to replace one (or even began to suspect wear), but I usually sell my Harleys and buy something else by maybe 65k miles at the most...
Old 2nd June 2011
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
Are you sure it's the chain? I know a guy with a 1988 glide with 200K mi. on the motor and he has never replaced the primary chain. It is constantly running in an oil bath. He said he has had to replace the tensioner as it has worn, but not the chain. Are you sure the tensioner isn't just worn?
2005 XL1200C
Those who trade liberty for security have neither.
