0 Brand new 2020 XL1200NS
0 Down on oil
Last Post: Billy1200
0 Vintage tires
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
0 Clutch release mechanism
Last Post: Rioo
View Poll Results: Belt Or chain conversion?
Keep the belt 119 78.29%
Get the chain 33 21.71%
Voters: 152. You may not vote on this poll
  #31
Old 19th December 2014
nucklhead13 nucklhead13 is offline
Sportster/Buell Model: 1000 xlch
nucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to behold
I've never had one snap. Only trouble when they get too loose or the link piece falls off.
Old 20th December 2014
bobscogin bobscogin is offline
bobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to allbobscogin is a name known to all
The decision should be between "belt or suspenders", not "belt or chain".
Bob
Bob S.----1992 XL883 1960 XLH
Old 21st December 2014
hey train I reckon so, the sprocket is as big as the tire!!! with some good grips, could go mountain climbing.
Graywolf Graywolf is offline
Live on a dirt road and have to travel down dirt roads some to get where I want to go.
Chain and sprockets about 8,000 miles max!
Belt goes 50,000 plus miles most of the time. Only need to change the pulleys every second belt.
I don't have to guess which is better for me. Got away from chains in 1981 and never looked back. Chains have some advantages, but none that outweigh the life of the parts issue for me. I was sick of changing chain and both sprockets every time I changed a back tire which was about twice a year.
Graywolf
Old 22nd December 2014
trainman's Avatar
trainman trainman is offline
I do a little of that too.
Old 9th March 2015
rejeanprimeau's Avatar
At 60k change the belt even if not broken, now if I'm stock with a broken belt I just call the OS and she'll bring me the old belt. Wait a minute, I had help a guy on a sunday ride, I need to call him to have my old belt back. LOL.
Old 26th March 2015
Just do a twist with the old belt and it folds up into a three layer 9" circle that packs easy. Also, having the used one as a spare makes a roadside install easier. Do remember the rotation orientation.
Old 1st April 2015
T-reXL1200's Avatar
T-reXL1200 T-reXL1200 is offline
T-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant future
Originally Posted by Rogster View Post
tired of hearing chain noise is why I switched to scooters, but now Im building a sporty chopper, itll be belt drive
If you don't like chain noise, you're gonna LOVE the racket of lifters, pushrods, and valves chattering like sewing machine falling down a flight of stairs at 80mph!
Old 16th April 2015
Riding with Angels
Real motorsickles have chains and spoke wheels I love the maintenance myself worth it for the old look. if you go chain clean and silicone the link clip after installation chain wax or lube occasionally and keep the slack out you will have many trouble free miles. of course I started riding when belts were not an option. Geezer Glide I would keep the belt
LIFE IS SHORT PRAY HARD!!!!
Old 18th May 2015
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant future
One of the biggest reasons I went to a chain was due to belt drone. At highway speeds my bike sounded like a 4x4 with mud tires running 65 mph on pavement. The added bonus of being able to run a bigger tire was all it took to convince me to switch. I can run a 140 90 r16 on the back with no rubbing on my 03.
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
