0 Seeking information on long lost "race" parts
0 Swingarm pivot parts
0 FTC - Harley-Davidson - Customers’ Right to Repair
0 Poor running bike trouble shooting help
0 Instrument of Expression, the next chapter of the Sportster legacy
0 West Virginia fall run 2022
Last Post: joes95bobber
0 Allegheny National Park III
0 Replacing brake hoses - 85 sporty
Last Post: seajay
0 Crowe's MC, Springfield MI
0 Axe's Harley History K/XL, FL, & Choppers vids
Last Post: axe
0 KT - 2022 - Show A Little Backbone
0 Former Biker
Last Post: Andy56
0 What did I do? Clutch adjustment question
0 Oil pressure light stays on
0 you tube screw up
0 Buell Wheel Bearing Information
View Poll Results: What band of sparkplug do you use?
Accel 32 2.85%
Champion 134 11.94%
NGK 350 31.19%
Autolite 94 8.38%
Bosch 17 1.52%
Splitfire 13 1.16%
Denso 34 3.03%
HD 309 27.54%
HD Screamin Eagle (any kind) 139 12.39%
Voters: 1122. You may not vote on this poll
  #351
Old 12th April 2021
Well, Jerry, it’s warming up and activity should skyrocket. Oh, think my gremlin has been vanquished, at least I hope so. Thanks!
Pleasing everyone is impossible but pissing everybody off is a piece of cake!
Old 6th June 2021
slonez slonez is offline
slonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud ofslonez has much to be proud of
Originally Posted by glbsportster View Post
I now use Denso Iridium (IXU22) gapped at .035 and all is well. ..The following from Denso
Increased performance with the World's smallest Iridium Center Electrode (0.4mm). To increase ignitability, the important point is to let the flame kernel produced by the spark to grow unobstructed. Normally, this can be accomplished by widening the spark gap. However, this causes spark voltage to increase, which has the opposite effect. Iridium Power uses DENSO's patented U-Groove ground electrode to achieve maximum ignitability while minimizing required voltage.
I am also using the same plugs.
I have gapped mine at 1mm, roughly 0.040.
Is 0.035 gap better for this plug?
Old 2nd April 2022
Air-Cooled Forever
Rule of thumb, Iridium plug gap is set at the factory and gapping them will damage the center tip (researching this will confirm my claim), Platinum Plugs should only be gapped once before installing. All others, standard and copper, can be gapped and regapped.
Old 2nd April 2022
WarlordATF WarlordATF is offline
WarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to beholdWarlordATF is a splendid one to behold
About a year ago, I put a set of NGK DCPR7Es in my 04 XL1200C with a new set of Red Moroso Wires running to the stock coil. It Works great! Not a single hiccup and the plugs are still in great shape after about 1200 miles of local stop and go riding.
Old 5th May 2022
sml1226 sml1226 is offline
Sportster/Buell Model: XL1275R
You don’t damage iridiums by gapping them. Platinums can be regapped just fine.
The damage comes from people using those stupid ramp gauges as an adjuster. It’s a measuring tool, not an adjustment tool. Bend the nice sturdy copper strap and don’t mash things against the fine electrodes. They adjust perfectly well. You just need to make sure you only measure the gap if you’re putting something up against the electrodes. Don’t apply force to them.
I have one of these for my car where I run ruthenium plugs. Those are even finer electrodes than iridium. They still need gapped properly.
Sportster/Buell Year #2: '03
splitfire triple platinum TP416D were these sold as screamin' eagle plugs? years ago? they came as a spare set with my '03.need an 11/16'' socket with these or maybe 17 mm.
