Last Post: Bow only
Last Post: Kbetts
0 Spark Plugs
0 xied or x14ied?
Last Post: Joe_jeep
0 Xlch spark plugs
0 Diagnostic code ?
0 Solenoid issue?
Last Post: Gulf Coaster
0 Resto-Repair 84 ironhead
Last Post: Hellbent_4
0 PSA on headlight shell wires
0 harbor freight lift
0 Digital odometer
Last Post: onadraw
10 The better than average BLUE bike thread!
0 Ceramic Wax
0 Don't drive angry
0 Talk to me about Painting
Old 11th July 2019
APJ CUSTOMS APJ CUSTOMS is offline
Sportster/Buell Model: sportster 883
APJ CUSTOMS is an unknown quantity at this point
Default Strange ignition issue need input ?
I wrenched for Harley in NY for some time and have been building bikes for over 2 decades that said I am stumped right now and it’s driving me
Nuts I have to believe someone in this forum can give me some
Direction with this issue -
98 883 front cylinder dosnt fire but if I half remove the boot of the ignition wire from the front spark plug it starts firing and I can hear the crackle and see a strong blue arc ! New screaming eagle wires which I replaced to deal with this issue along with the plugs yet the problem Persist ! Coil seems to check out when I tested to me I would think there was a short or Bad ground just like I’d expect the plug to fire with the ignition wire fully seated and not fire when half removed ? Any input would be greatly appreciated Im just finishing sone upgrades on my 03 road king and now I’m
Back to stressing over this ignition / electrical issue !
Thanks to anyone who can steer me in the right direction !!!
Old 11th July 2019
harley506d's Avatar
Sportster/Buell Model: 1200c
If you haven't already, i would swop stuff around to see if it follows you.
Sounds a weird one though. Someone will be along soon to help, hang in there!
Old 11th July 2019
Air-Cooled Forever
Clean out the spark plug hole. It sounds like the spark plug is not grounded.
Old 11th July 2019
I would wire brush the inside of the Coil towers...
If the ignition is original, it is still dual-fire and you can swap the plug wires at the coil to see if it is just one tower that is mis-firing...
Old 12th July 2019
I’m leaning toward a possible compression issue what I’ve learned is pulling to plug boot away from the plug causes the coil to fire harder which is an old MX racer trick but I’m this case could Translate to a loss of
Compression but also like mentioned it could be a faulty coil tower someone told me a while back this model is single fire there are only 2 post and 2 coil towers I’m going to have to do some further investigating thanks for all the input let’s see what translates tomorrow when I did a little deeper all I can say is luckily I have my RK and my R1 to ride so at least I can’t gets some frustration out while I work this out thanks again everyone
Old 12th July 2019
1998 models are Dual-fire (unless Sport Model) (2-inputs - 2-towers)
All 2004-later models are Single-Fire (3-inputs - 2-towers)
Here's the Sportsterpedia section on the Ignition Modules:
http://sportsterpedia.com/doku.php/t...k:evo:engctl01
Here's the Sportsterpedia section on the Coil:
http://sportsterpedia.com/doku.php/t...-_specs_checks
Here's the Sportsterpedia section on Compression & Leakdown tests:
http://sportsterpedia.com/doku.php/t...:evo:engmech03
Old 12th July 2019
Thank you great reply with great content to work
With I greatly appreciate it ! Will get back to post updates when I can
Old 14th July 2019
when you pull the wire up it is like adding resistance to the secondary and the coil responds by building more voltage till i can jump the gap. this also creates heat and loads the coil. most plugs will fire in the 8k range and as resistance goes up will increase kv, that said, a 50k coil will fire around 8 and the progressively go to 50k.
two things come to mind, saturation of the coil is limited due to ign module and the coil has an internal defect. when using a vom, it is basically a go/no-go test as it cannot pick up a shorted winding. if the coil got hot, the insulating varnish on the wire could have broken down allowing leakage at high voltage something a vom can not find.
best bet is to find a shop with an ign scope and see what is going on.
Old 30th July 2019
Sorry for delay life’s been crazy that said I’m leaning towards the ignition module end of
Things ! I started searching erratic spark and found a couple other people in the same
Exact boat with the 98 883 evo and their solution was to install new ignition module ! My coil dosnt show any signs of damage no cracks or serious swelling it appears to test as thow it’s functional and I don’t see how I could
Be getting the rear cylinder to fire and the front cylinder to fire if coil is bad granted I have to unseat the spark plug boot about a 1/4 inch for both cylinders to fire but when I do the bike sounds normal and rides normally so now I’m wondering before I throw $100 and a bunch of work to replace ignition module is theee a relay or something else to check first that’s online with ignition module?
Old 30th July 2019
rurlndum rurlndum is offline
rurlndum is an unknown quantity at this point
Change the spark plug.
